0 Members and 46 Guests are viewing this topic.
mikewatson
Has anyone managed to repeat Naudin's original experiment with carbon and thoriated tungsten? As reported I got something in my attempts but very much less than Naudin. I vaguely recall that someone on this thread said they had repeated it. Was it "Uncle Fester" or "Feynman" or someone else? Otherwise it means trawling through over 860 messages.
Mike
sparks
    The sparks in a microwave arize from conversion of a non-ionizing wavelength absorbed into a metal lattice and retransmitted at an ionizing wavelength.  This ionizes the nitrogen inside the cavity and a plazma string evolves.   This plazma string now has a life of it's own.  You got yourself a lightning bolt.  I'm not sure if this is going to happen with carbon. My wife won't let me put anything but food in the microwave after she saw the ball lightning from the grapes I put in there.  Heading for a flea market to pickmeup a junk one.  Seems a copper coil should be able to be wrapped around the carbon as long as attention is paid to the dielectric field relative to the copper coil geometry.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Reiyuki
Well, was playing with my setup over the weekend.  Here's the runthrough:
- Power Supply
12kv 30ma NST (360watt)
- Capacitor Bank
0.0143 ?F capacitor @ 12kv (2kv .1uf   x7 series)
- Carbon rod
.25 dia carbon rod, 6" long  (.995 pure)
- B-field
Neodmium magnet and 9v battery biasing toroid windings
- Toroidal Transformer
http://www.allelectronics.com/make-a-store/item/TTX-7812/TOROIDAL-TRANSFORMER-7.8VAC/6.3A-25.2VCT/2.2A/1.html
  Input: 100/120/240 Vac 50/60 Hz. Output: 7.8Vac @ 6.3A, 12.6Vac @ 1.1A, 12.6Vac @ 1.1A3.5" diameter x 1.38".
Summary:  Setup was in such a way that a spark gap triggered and dumped all the energy through the carbon when reaching ~12kv.
  Made a lot of noise and ozone, but no usable power.
Details:
  Measurement was limited with a lack of oscilloscope, but was able to estimate voltages by using a bridge rectifier and cap through to a meter.
  Power through the 120v line on the toroid broke 1kv at less than a milliamp (barely lights an LED).
  Using a large stepdown for measurement, voltage was down to ~350v with no real power.
  Was getting high voltage through all the transformer windings at very low power.  Probably acting as a flyback or something.
  Did try a small self-run for the hell of it.  120v windings from toroid phased into 120v input on NST.  AC power initialized for .5sec.  No smoke, but no power either.
Conclusion
The joules-per-pulse on the capacitors is likely way too low.  This HV setup will be scrapped in preparation for the next version, a 300v setup with some big bertha capacitors.
  - Reiyuki
AbbaRue
I found the following subject on this forum closely related to what we are trying to achieve here:
http://www.overunity.com/index.php/topic,2827.msg122875/topicseen.html#msg122875
The patent they are speaking of can be found here:
http://free-energy-info.co.uk/PatD13.pdf
Download the patent info and perhaps it's principles can be applied to the carbon rod.
Maybe we should be grinding the carbon rods into powder and making a similar unit.
We just need to find the right frequency for carbon.
Unless 300MHz will work for carbon as well.
forest
Quote from: AbbaRue on June 25, 2008, 01:49:16 AM
@eldarion
I think the answer has been given.
Most of the beta is absorbed by the carbon and transformed into another form of energy.
Some will be EMP, some as heat.
Only a small portion of the beta from near the surface of the rod escapes the rod.
In fact the EMP produced from the beta colliding with the carbon atoms is probably what we want to harness.
This is the purpose of the B field, to align the EMP inside the rod.
Without the B field the EMP would move in random directions and be lost as heat.
The term Colliding used above may not be the right term, it's only used to illustrate the point.
How the beta is transformed into EMP is unknown.
So no rebuttal is required.
How about : beta is abruptly stopped but not magnetic field, EMP is produced, pure magnetic wave ?
