argona369
Though the original device in this thread is probably fake.
The concept seems hopeful.
In the spirit of Tesla (his mass of infinitely small size) and Testatika (you can see that in the Testatika that their cylinders
have a slight coating of graphite (reflective metallic coating))
here's one good example, (thank's steve, good site)
http://rimstar.org/sdenergy/testa/misc/TESTA4.JPG
What about a dielectric rod or a cylinder rubbed with a pencil or graphite powder?
?It is now presumed that tiny fragments of graphene sheets are produced (along with quantities of other debris) whenever graphite is abraded?
http://en.wikipedia.org/wiki/Graphene
high voltage/ high resistance of course.
Cliff,
mdmiller
possibly this is the same Eric d'Hoker, now at UCLA ??
http://personnel.physics.ucla.edu/directory/faculty/index.php?f_name=dhoker
originally schooled in France, PhD from Princeton
according to F Vallee site, the carbon rod synergistics test as pictured was " was selected for
the first generator synergistic due to Belgian Eric d' Hoker. "
aleks
One idea - why not try to put carbon rod in such configuration: It won't take much experimental time, but maybe can show something of importance. I just have a suspicion that magnetic field amplification is most powerful along carbon rod's discharge axis, not perpedicular: the reason for that is that if magnetic monopoles are appearing along the axis together with discharge flow their summary field will create a kind of arrow along the axis. Maybe worth trying, but of course I may be mistaken.
Mechanical rotation may also be useful when dealing with emerging magnetic monopoles: this way you can give a statistical direction to current they may induce. For example, a carbon rod discharger mounted in the center and along the axis of a rotor. Just thinking out loud...
aleks
Quote from: allcanadian on May 23, 2008, 12:25:42 PMWe must see past the illusions of effect and examine cause and there we will find only electrostatic forces, maybe what Moray refered to as cold plasma.
Gaseous aether with electrostatic fields being represented as ionized clouds (cold plasma) of this aether is something very close to what I 'see' myself. However, since I'm pretty much IT-geared, I perceive it as a 3D scalar matrix with each element of this matrix equal to amount of "ionization" in a given position in space. Then you can define any "ionization" clouds, and define laws of transformation of these clouds.
tak22
Part of a translated commentary by Charlie Renegade, whoever he is  ???
The theory of Synerg?tique developed by Professor Valley offers another means by a simple experience: - Pick up a piece of pure graphite (pencil extra dry 4H, kernel stack coal, etc.). A small amount is enough (10 grams), you will understand later. -- Attach an electrode at each end of the stick of graphite. -- Surround the stick of a coil of copper as to create an electromagnet. This will give you the transformer primary to a new genre. -- Put this little montage at the centre of a winding torus to be secondary to the processor.
Before going further, to summarize: You must have a stick with a graphite electrode at each end, surrounded by a winding, all located in the centre of a winding torus. Make you a GBF (low-frequency generator) and a phase shifter and connect them so that you get two sources sine (50 Hz is sufficient) out of step one over the other (the angle phase shift Not ;-). Connect a source directly onto the stick of carbon and other source out of sync on the terminals of the first coil (the one that surrounds directly carbon). Carbon is thus simultaneously excited by an electric field and a variable magnetic field varies with the same frequency but d?phas?. By playing on the phase angle, Professor Valley affirms that finding the right angle, the electron of the carbon atom enter into resonance, is destabilized and falls on the core, thus turning carbon 12 in bore12 much energy radiation ? (beta). The radiation is recovered by the winding torique which turns it into electricity.
The experiment was made in Belgium by physicist Eric D'ocker (or D'Hoker or even D'Hocker), which claims to have obtained secondary 4x more energy than it would have sent the primary. Myth or Reality? Where does the energy thus created? The professor said that referring Valley Energy and amplified in the primary (carbon + winding) it is possible to amplify the power of the current maximum of 8 kW per gram of carbon. Any replacement of carbon by another material is ineffective (no amplification). It is therefore possible, from a small electrical pulse to start, get an electric current self-powered and self-amplified from a single stick of carbon? Professor Ren?-Louis Valley states, Professor Eric D'ocker confirmed.
