NASA Report on Tesla's Zero Point Energy (page 41)
Started by rukiddingme, December 10, 2012, 02:25:13 AM
rukiddingme
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20050170447_2005172301.pdf
3.3.7 Long-Range Longitudinal Wave Transmission Finally, the BSRF researchers demonstrated longitudinal waves being transmitted and then received several thousand feet away. Inside the BSRF laboratory building a conventional continuous wave (CW) radio transmitter was connected to the pancake transmitter coil. Outside (on the seashore beach 3,000 ft away), a conventional (shortwave) portable radio receiver was connected to the pancake receiver coil, which in turn was connected to a copper screen immersed in the ocean as an "antenna" for the longitudinal waves. The signal reception [at a frequency of 2.94 megahertz (MHz)] was shown. It was not demonstrated to what extent the screen immersed in the ocean was augmenting the reception process; however, it should be noted that there was no "line of sight" from the transmitter to the receiver and the transmission distance was too short to use reflecting the signal from the ionosphere. It was also stated that the transmitter location was not only 3,000 ft away but was behind a mountain. Therefore, the point of the BSRF demonstration was to show that longitudinal waves (at this frequency) can more readily penetrate matter than can transverse waves.
4.3.6 Summary of Principles for Accessing ZPE It is possible to summarize the respective principles used by Dr. Nikola Tesla and Edwin V. Gray to release what each inventor claimed was an output energy greater than the input energy, as follows: 1) Generate a relatively high voltage by an applicable method. 2) Discharge the voltage across a spark-gap. 3) Control the duration and direction of the discharge. 4) Capture (with a metallic receiver that is not directly connected to the spark-gap) a (postulated) "mass-free" component of electricity that is radiated from the discharge. 5) Feed a sufficient fraction of the captured energy back to continue Step 1. One can hypothesize that the "mass-free" "radiant electricity" momentarily coheres and collects a very small amount of the ZPE field as it traverses the space between the discharge and the metallic receiver and that the collected energy is significantly larger than the energy dissipated in the initial spark discharge.
Neo-X
Thanks for sharing this info. This is another proof that ou really exits. But i just wondering, whats so especial about pancake coil than cylindrical coil? Tesla's pancake coil is wound in bipillar but we can also make a bipillar in cylindrical coil. Would the pancake coil have less inductance than cylindrical coil?
WilbyInebriated
Quote from: rukiddingme on December 10, 2012, 02:25:13 AM
3000 feet away yet "behind a mountain"? a little over half a mile away and yet behind a mountain?   that's pretty small "mountain"... or a pretty big exaggeration. ;)
anyways, thanks for the link. it was a very interesting read!
golfinj98
Better copy and whatever was posted here. Went to use that link and it was not accessible.
WilbyInebriated
Quote from: golfinj98 on December 10, 2012, 05:55:40 AM
i had no problem downloading it a short while ago. i'll post it to the download section here at overunity.com. link coming shortly...
edited to add link: http://www.overunity.com/downloads/sa/view/down/522/
