UFO politics Keeps his word 12-12 12 Let the games begin.......
Started by ramset, December 13, 2012, 08:15:14 AM
ramset
Spinner
You big creep  ;D  ........Good to see yah!
Have a good holiday,
Go out and do something nice for some one today and don't get caught.
Chet
Thanks Grandma
tinman
Quote from: ramset on December 22, 2012, 07:46:31 AM
TM
Please be advised ,any time you use the B word and O word together in the same sentence on this forum
Well................B.O.
I must also add that there is some part Of this Battery thing, that as you state above does need to be better understood .But
ultimately the simplest thing to do is cook eggs in the parking [batteries not included] lot or Loop the system
Thx
Chet
Hi Chet
Well you lost me on the...B.O thing,but anyway
Cooking egg's in the parking lot is easy,just throw them on the bonnet of your car on a hot day-and they will cook.
Even a solar cooker will cook snag's and egg's,no problem.And we are collecting energy from the enviroment to do so !! free energy !!.
What i was trying to point out is,it is very easy to show that you have an overunity device-there is just no need for all these half done measurments that we have seen.
And like you said Chet,!! loop the system.!!
Any overunity device will run itself at the very least.
ramset
Thanks Grandma
ramset
The Consensus from the "Heckspurts" here is Over Unity =batteries not included.
Myself I chose to listen and learn [and experiment of course ].
thx
Chet
Thanks Grandma
Tinman:
A very good course of action in the UFO-modified motor case would be to do load testing on unmodified and then modified motors like I suggested.  PW wrote up a more comprehensive test plan based on the same idea of using another motor in a generator configuration with a load resistor as the mechanical load on the motor under test.  This is a manageable and doable test that any experimenter should be able to do.  The most important thing being that you can actually generate tangible data.  It's really unfortunate that the contributors on the EF thread that are lurking here are not saying anything.  The EF thread has been going on for months with no third-party tester data to confirm or deny UFO's claims about his modified motors.
Your proposed test could be done if there was any data from the above proposed motor-generator test that indicated a chance of a self-runner.  The essence of your test would be to see if the battery was charging or discharging during the run.  In that sense you could put a big shunt on the positive terminal of the battery and connect a resistor in series with a capacitor across the shunt like PW indicated in an earlier posting.  That will give you a low-pass filter and all that you have to do is look at the DC voltage across the capacitor to know if the battery is charging or discharging.
Battery voltage is not a reliable indicator of the state of charge of a battery.  So instead of reading the before-after battery voltages you could discharge it after the test and measure the energy stored in it.  You would have to know the initial amount of energy in the battery beforehand by doing other testing.
