Magnetic energy pump OU motor
Started by wizkycho, August 05, 2006, 09:30:43 AM
wings
Quote from: wizkycho on April 10, 2009, 04:36:54 AM
...so after establishing that this is magnetic reluctance motor type... dating from 19th century (but unable to be driven efficiently, no mosfets - at that time, so design was abbandoned till recent years)
their properties are (unlike induction):
- lentzless motor
- no back force (or any back effects) from applied load
- since efficiency of these types of motors is very high (higher then induction mot.) they again, in last 10 years, arrise in production quantity.
further (only in OU and FE development - not yet in industry !?!):
- by adding permeable magnets and established and prooven Magnetic Transistor (using change in reluctance) theory/practice
efficiency of these motors must exceed at least 100%......(many finished experimental - Hildebrand, Flynn .... motors confirms it is so and even reaching 200% - 300%)
this is where this thread will continue from:
http://www.overunity.com/index.php?topic=1319.msg164396#msg164396
this experiment allso solved some questions:
nonoriented silicon iron is good material for this motor - no residual magnetism after coil is switched off (but using frq 1khz and lower is must - for now lower freq. the better)
(but even if there is residual mag. - specially build stator sequence with changed polariti of mag. transistor can reuse this magnetism....)
...due to luck of small money surplus...further development of actuall motor is on hold for some time....
Perihelion Labs
At least 175% OU see this.
http://www.youtube.com/watch?v=nzVXAm_ONIk&feature=channel_page
some experiments
http://www.youtube.com/watch?v=aUxQHkkRSoc&feature=related
http://www.youtube.com/watch?v=9Nlspw1HY-w&feature=channel
Dr.Imris let convert a conventional 4 KW electric motor with his "capacitive winding concept",
then it was used/connected with the 4,8 KW(KVA) electric generator, taken away from a conventional "homedepot" internal-combustion-motor/generator-system, and tested:
input 528W and output 3375 W .
Sincerely
             Lança
gyulasun
Hi Lança,
Don't you know how Dr. Imris would explain the origin of the higher effective output than input?
Thanks,
Gyula
PS   Is there any new 'baby' forming on your side?  ;)
Hello gyulasun,hello buda and pesta,
Dr. Pavel Imris probably explains the technical process in his, actually non disclosed, patent !
Publicated is only the "more common" GM(Gebrauchsmuster).
More help would be to understand the "Cornelius Lungu,capacitive winding"
+ integrated in a condensator/condenser cycle !
"Babies ?" With two legs and a "nice Vorbau"(viel Holz vor der Huettn, in bajuwaric) :  :-* ?
Actually- time out-   :'(:-[ , : strikte clausur !
Without legs and only TEC
2007:BBI  2008:BBII- 2009:BBIII: C.O.P. only 11(eleven), cause other concept.
Have a nice week
                         Lança
wizkycho
Quote from: lancaIV on April 13, 2009, 08:33:55 PM
Have a nice week
                         Lança
This is for Tesla resonance topic. And since there are no data on actuall construction ...all of it is just impossible.
I'm more then satisfied with Magnetic Transistors COP 1.8 - 3 times and looped.... ;D
Wiz
