Magnetic energy pump OU motor
Started by wizkycho, August 05, 2006, 09:30:43 AM
Ergo
Quote from: smithandwes on December 16, 2008, 05:48:45 AM
looks like an awesome idea..i might just try it.  I know someone else did a similar setup.. but the coil was on the outside of the ring.  He had some promising results.
What does "promising results" mean in a forum like this.
If you refer to plain movement/rotation it means nothing.
If you mean anything else but confirmed overunity, it means nothing.
wizkycho
Hi all !
...done some extensive research in magnetic amplifier domain and must say Magnetic Amplifier term has absolutely nothing to do with
Hildebrand, Flynn, Genesis, JNaudins MEP... processes
of rerouting magnetic field.(all different approach-setups but resulting in much stronger Mfield at output than can be even produced from energy invested at input by any type of coil of any efficiency)
...all of these processes can be unified in Magnetic Transistor term... so indeed Magnetic Transistor is completely new invention proven by many experiments even somewhat allready blindely used in industry but without any awareness of its real properties.
so Magnetic Transistor is invented here at overunity.com and knowledge-awareness of it's properties is new.it's not resurection , but even if it is, it deserves much closer observation and attention
Magnetic Transistor main researchers:
Jnaudin (MEP)
Flynn
Hildebrand
Genesis
Let's say it outloud and give ourselves some credit we really invented this. We established it, recognized it's properties, defined it, and made it possible to replicate. nobody but us.
Allso Invention of Magnetic Transistor (four types are known) can lead to mass-(anti)gravity manipulation.
@Harti
- I suggest (You)we put this discovery red glow at start of home page. together with Milkovich pendulum and Butch's pseudo solid magnet motor
Magnetic Transistor is really news
- my avatar is not shown (maybe settings in my IE ?)
Wiz
Looks good.
No iron lamination?
What about eddy currents then ?
Let us know your test resultswith a video and I will
put it into the news section.
Many thanks.
Regards, Stefan.
P.S: Avatars are disabled in this moment until the new SMF 2 Software will be used
due to security.
konduct
Quote from: Ergo on December 16, 2008, 10:49:33 AM
I completely disagree and decided to comment about comments like this. So you understand...in case you don't do physical research yourself...promising results most likely indicate that someone is researching a previously unknown effect, and by relatively blind empirical testing, their results seem to indicate proper understanding of an effect. If you're getting confusing results, then you need to change your understanding. Promising results do mean something. They mean we are beginning to understand, each on our own personal levels. Continue on and be safe with the research.
wizkycho
Hi all !
about exepriment:
...here clearly can be seen that static field of permanent magnet is fluctuated at desired point (rotor)
this is very crude experiment since:
- rotor permeability only 400 (tooooo low)
- air gap 1.2mm (tooooo big) - 0.3mm possible - same pressure for much lower power input
. magnet 5mm smaller (and round) then cores
. genesis type (Hilden Brand type has even better efficiency)
. core is not even rounded for rotor
- electric input is done with pulse width modulator on 2*BUZ100 filtered with 10000uF/40V
- fluctuation of pressure generated is around 2* times greater then coil used only.
fluctuation of magnetic field is direct cause of creating KINETIC ENERGY. 90% todays electromotors uses
for knowledgable nothing-but-underunity (that dare to compare magnet with accumulator or capacitor):
    hundred of meassurements have been done and magnet did not lower its strenght (preassure same - for same input power).
With power spended on coil probably 3 or 4 additional magnets could be made, but magnet didn't lose it's strenght a bit after more then 100 applied strong fields.
(cause even TODAYS SCIENCE KNOWS that magnet will start to deplete (lose strenght) if direct repulsion is forced AND that forced field must be 50-80%(depending on type) of strenght of magnet itself
- that is threshold when magnet only starts to deplete. below that threshold - free permanet magnetic field lasts long enough to say forewer)
Now with Magnetic Transistor functional one more of many ways of generating Energy surplus is certanly opened.
Perihelion Labs
