converting cosmic rays to electricity comparing to T.H.Moray's device
Started by yellowsnow2, January 28, 2013, 02:01:48 PM
yellowsnow2
Thomas Moray's book "THE SEA OF ENERGY" http://globalfreeenergy.info/2011/11/25/full-text-book-the-sea-of-energy-by-thomas-henry-moray-p1-p18/ Talks about being surrounded by a sea of vibrational energy and also hints that his device was a siphon for this energy.
So thinking in that perspective I made some interesting finds.
From my understanding you can look at the Geiger tube as a transformer that turns ionizing radiation into electricity. It does this using an electron avalanche or Townsend avalanche.
"The tube consists of a chamber filled with a low-pressure (~0.1 atm) inert gas. This contains two electrodes, between which there is a potential difference of several hundred volts. The walls of the tube are either metal or have their inside surface coated with a conductor to form the cathode, while the anode is a wire in the centre of the chamber. When ionizing radiation strikes the tube, some molecules of the fill gas are ionized, either directly by the incident radiation or indirectly by means of secondary electrons produced in the walls of the tube. This creates positively charged ions and electrons, known as ion pairs, in the gas. The strong electric field created by the tube's electrodes accelerates the positive ions towards the cathode and the electrons towards the anode. Close to the anode in the "avalanche region" the electrons gain sufficient energy to ionize additional gas molecules and create a large number of electron avalanches which spread along the anode and effectively throughout the avalanche region. This is the "gas multiplication" effect which gives the tube its key characteristic of being able to produce a significant output pulse from a single ionising event.[4" http://en.wikipedia.org/wiki/Geiger%E2%80%93M%C3%BCller_tube
So if you look up ionizing radiation, cosmic rays ARE on the list. http://en.wikipedia.org/wiki/Ionizing_radiation
And if you look into Thomas Moray's device he had an antenna bringing cosmic rays to his tubes/valves and he also had radio active material IN the tubes/valves.
I think of radio active material as a tuning fork tuned to a very high frequency sucking in and resonating with surrounding energy of the same frequency.  So did Moray put the radio active material inside the tubes creating a resonant circuit tuned to cosmic rays?
Is this a way to siphon the sea of energy that surrounds us?
These are some of the experiments I will be performing in the Captret section http://www.overunity.com/13273/i-will-be-testing-high-voltage-capacitor-self-charge-t-h-moray-style/#.UQbIIGc7LRM
Other relevant links= Townsend discharge http://en.wikipedia.org/wiki/Townsend_discharge  Electron avalanche http://en.wikipedia.org/wiki/Electron_avalanche
yellowsnow2
Looking at the available pictures of Moray's tubes, http://www.freeenergyplanet.info/free-energy-devices/images/2370_631_275-thomas-henry-moray-device.jpg I can see this theory really taking shape. You can look at this tube as a self exciting Geiger tube. Where the electrodes on the left are a Geiger tube/dynatron and the stuff on the right shoots x-rays (ionizing radiation) at it. It can be theorized that by running power through a loop like this would gain power from the gas multiplication effect of the Townsend avalanche and maybe the negative resistance characteristics of the dynatron (which doesn't need a heated cathode because the x-ray emitter supplies the electrons). http://en.wikipedia.org/wiki/Dynatron
The many strange qualities of vacuum tubes fascinate me and seem to have more potential for free energy than conventional electronics.
yellowsnow2
Did some more research..
The Townsend avalanche seems to be the same thing as the nuclear chain reaction that powers nuclear power plants..... Except on a smaller scale  (in the ion scale instead of protons and neutrons)....without radiation emissions (that aren't used)......And in a safe way because of the process's self limiting effect "Raether limit" where the gas in the tube becomes so ionized that it becomes conductive and self discharges .. in contrast to the run away nuclear chain reaction that ends up as a bomb.
It acts as a free current amplifier....
So by introducing one elctron or positron it will put out around 1000000000 to 10000000000 electrons.
e2matrix
Keep up the good work.   It may be there is a lack of responses here as Moray's work has been discussed at length before.   Probably one of the most in depth researchers on his material is Bruce Perreault.   Are you familiar with him or his work?   He has a web site or two (may have changed recently) but try www.nuenergy.org and www.sonomagnetics.com  if you don't already know about them.
yellowsnow2
I have probly been over them links but I will check. Seems like I have read everything available on Moray. Even buying books that aren't available on the net.
Moray talks about his "detector".... I believe when he says detector he is talking about a version of the Geiger tube, which can also be used as an oscillator.
Here is a guy who puts a commercial Geiger tube on an oscilloscope.   400v input from 2 AA batteries to run it. Every ionizing event  creates a negative -4000v spike.  But you have to realize that a commercial tube is designed to completely ground/breakdown/discharge from one event. I will be designing my own to get the best characteristics.
http://www-cs-faculty.stanford.edu/~nick/geiger/
I can easily picture building a wide flat Geiger tube to act as a solar/cosmic ray cell.  I believe Tesla's cosmic ray collector using an insulated metal plate on antenna does the same thing without the avalanche amplification.
The charged electrodes are just to suck the electrons to it. As the electrons get closer the stronger (magnetic?) field of the electrode acts as a particle accelerator. Acceleration past a certain speed creates energy for the avalanche effect.
So I want to do some testing with already accelerated electrons from an electron gun/cathode ray tube, which I understand could work from high voltage static electricity too. And instead of relying on the electrode to suck the particle in, I want to try just shooting the electrons at the electrode plate.
