Graphene Made at home, producing voltage. Sharing all with you tonight.
Started by Hope, February 27, 2013, 01:33:55 AM
Paul-R
Quote from: e2matrix on February 27, 2013, 01:55:24 AM
Hope,  that's impressive work.   One thing I wasn't clear about in your description
involves writing in black to the DVD
I take this to mean that when writing to the DVD, the video needs to be of a collection
of black frames, i.e. a "movie" made with a camcorder with the lens cap on.
mikestocks2006
Quote from: DreamThinkBuild on February 27, 2013, 11:35:49 AM
Hi Hope,
Thanks for the information really cool stuff.
Hi Bruce,
Was this the video?
http://www.youtube.com/watch?v=_oEFwyoWKXo#!
Paper(source: hackaday.com)
http://hackadaycom.files.wordpress.com/2012/03/laser-scribing-of-high-performance-and-flexible-graphene-based-electrochemical-capacitors.pdf
Hi DreamThinkBuild
In the video he appears to be using a special burner, with the laser emitter on top, as opposed to the standard dvd drives where the beam shoots from the bottom. ( the professor pulls the cd out of the drive with the etched surface facing up –top)
There is no mention of how many layers of the paired surfaces are used for the demo capacitor.
Lightscribe ™ shows a standard dvd burner where the laser hits from the bottom. That may cause problems with the oxide solution as it will have to come in contact with the dvd tray first and damage it.
From their website: http://www.lightscribe.com/support/index.aspx?id=1526
Click on  LS Simple Labeler Demo (2min, 2MB)
It would be interesting to find out the most cost effective/useable substrate, electrolyte, separator combination for this process.
Thanks for providing the links.
Mike
Bruce_TPU
blueplanet
MT Keshe and many of his followers have already done this.
By the way, what was the highest voltage you can get?
(EDIT: 1 millivolt - 2 millivolt is too small. This voltage might well come from the random space charge rather than the graphene metal junction.)
(EDIT AGAIN: I think it is also important to give credit where credit is due. )
