The main question is: Why Gravity takes effect on Matter?
Started by derekwillstar, April 08, 2013, 09:10:46 PM
gravityblock
Jbignes,
It is what it is, so don't get your panties all in a knot, lol.  What your saying hasn't been proven anymore than what I'm saying.
Gravock
gravityblock
Quote from: jbignes5 on May 02, 2013, 02:57:15 PM
Until you can show this premise then it will never float. The moon is very hollow and it has been proven by objects hitting the moon then the moon rings for hours afterwards. I will agree with that.
The singing sand dunes on earth also ring for hours on end, and they are not hollow.  You're argument that the moon is very hollow because it rings for hours when being hit by objects doesn't hold until all other possibilities have been ruled out.  According to your line of thinking, the singing sand dunes is proof for a hollow earth, which you don't accept
Gravock
jbignes5
Quote from: gravityblock on May 02, 2013, 03:12:23 PM
Jbignes,
Gravock
It is being reproduces every day through experiments and observations of our galaxy. This has been proven for a very long time by experimentation.mValid experimentation. Just look up the thunderbolts project.
jbignes5
Quote from: gravityblock on May 02, 2013, 03:31:00 PM
The singing sand dunes on earth also ring for hours on end, and they are not hollow.  You're argument that the moon is very hollow because it rings for hours when being hit by objects doesn't hold until all other possibilities have been ruled out.  According to your line of thinking, the singing sand dunes is proof for a hollow earth.
Gravock
As said before I back my examples up with actual evidence. NASA has reported the ringing incident many times by observation.
The singing sand dunes is because of our atmosphere and the composition of the sand in question, it has little to do with objects that hit the dune. Where is the proof you might offer about the singing sand dunes and the exact way that each the sand dune and moon act respectively?
Is this your example that you are referring to?
http://en.wikipedia.org/wiki/Singing_sand
lets do some reading and see that it does not last hours.
"Singing sand dunes, an example of the phenomenon of singing sand, produce a sound described as roaring, booming, squeaking, or the "Song of Dunes". This is a natural sound phenomenon of up to 105 decibels, lasting as long as several minutes, that occurs in about 35 desert locations around the world. The sound is similar to a loud, low-pitch, rumble, and it emanates from the crescent-shaped dunes, or barchans. The sound emission accompanies a slumping or avalanching movement of the sand, usually triggered by wind passing over the dune or by someone walking near the crest"
So lasting as long as several minutes to you means several hours?
There is a certain proceedure that needs to be done to get the results you are talking about. None of which meet the example of the whole moon ringing, not singing or barking.
Here is a report for you from NASA on the ringing and not singing...
http://www.omg-facts.com/Science/The-Apollo-12-Mission-Crashed-A-2-5-Ton/55549
And this report from the men who were there:
http://www.nasa.gov/exploration/home/15mar_moonquakes_prt.htm
gravityblock
Quote from: jbignes5 on May 02, 2013, 03:36:03 PM
Maybe you should look up Primer Fields and the Physics of the Primary State of Matter.  Also, why is there no measured electric field in a PM?  According to you, there can be no magnetic field without a moving electric field.  This isn't the case for a PM.
Gravock
