Magnet coil cores, demagnetization power and Lenz delay.
Started by synchro1, June 09, 2013, 11:07:49 AM
synchro1
Two powerful magnets, one on each side of a ferrite core coil would allow us to compare diametric polarization output to axial. Imagine a ferrite core, wrapped in it's own coil as a core, or a coil with two smaller coils T'd in from the sides with variable power control like the magnetic amplifier.
                                    Controlling the core field would act like a tuner!
synchro1
This latest video by Skycollection previews a Pancake bifilar with a ferrite toroid wrapped in a coil inside the center of the Pancake. Skycollection maintains this coil causes "Lenz Delay". This looks just like the "Magnetic Amplifier" I just invented for the Trifilar solenoid! Jorge measured an overunity COP of +3x with these kinds of coils. A JLN 2Sgen?
http://www.youtube.com/watch?v=jMgB7YnvxWM[/size]
synchro1
Imagine a solenoid ferrite core wrapped in a coil. One end of the core coil connected to the positive of the power source, and the other in series with the inside wire of the solenoid coil wrap. The pulse should generate a magnetic field in the ferrite before the outer coil does. This is how I believe Skycollection's toroid works.
The other alternative would involve placing a bridge of tiny neo disk magnets between the inside edges of Skycollection's ferrite toroid!
The impulse strength of the serial bifilar coil makes this winding configuration preferable to the single wire for the generation of demagnetization power. The SBC produces a stronger field collapse from the rotor departure, back on it's own remnant core field!
There's a "Magnet Pump" event in the sequence of events starting with the pulse through the rotor magnet decoupling. There's a remnant magnetic field in the ferrite that the outside field collapses on when the rotor departs. That generates the "Demagnetization" output from the ferrite core.
skycollection
Yes you rigth,the demagnetization out put from the ferrite core, produce more output...!
