New Tech
Started by lancaIV, July 12, 2013, 05:35:09 PM
Air conditioning Resonator ( heating, cooling)  : heating power for 20 sqm living area  in average 80 Watt
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=202008007815&OPS=ops.epo.org%2F3.2&apikey=TSMqTfrVAvNtryGI8Qlfbozj8DnAGlqJ&SRCLANG=de&TRGLANG=en
                                              1 Watth electric ~ 1,8 Watth PE energy-mix in Germany
                           Average. 80 Watt consume/20 sqm =            Solar Passive/Active house Energy Standart
                                           =    7,2 Watt PE/ sqm.                  <                               10 Watt PE/ sqm
                           Panel + controler production costs ?
                         10-15 Euros/sqm living area would be attractive as endconsumer price  !
                          Heat power performance improveable ?
heating power for 20 sqm living area 100 Watt : caloric output ~ 500 Watt
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=20&ND=3&adjacent=true&locale=en_EP&FT=D&date=20110518&CC=CN&NR=201836980U&KC=U#
https://patents.google.com/patent/US5130608A/en  as " power controler"
https://worldwide.espacenet.com/publicationDetails/biblio?FT=D&date=20030424&DB=EPODOC&locale=en_EP&CC=US&NR=2003077078A1&KC=A1&ND=4#
[0015]  :) this heating element is in production and sell in China
Performance calculation : before 500 caloric Watt output for 100 electric Watt input
optimized :
500 caloric Watt output by 75 Watt Bei Wei Wu IR-lamp and 37,5 Watt net electric "power controller" input
(the "power controller" before 100 W after : 4+8 W ratio is light - not heat related  ! )
The second I estimate with 100 Euros the heater and 37,5 Euros the " power controller" as endconsumer price  ! Only heating,  with the "Resonator" also cooling option  ! ( for example with solar cells )
In the southern Europe with 0°- 20° = 20 K temperature amplitude an 80 sqm apartment( conventionalconstruction) needs 4000 Watt caloric heat : 4000 W/ 500 W Zhang-heater output = 8 heater
= 2 heater per 20 sqm. !
In -20°/ + 20° = 40 K temperature amplitude = 4 Zhang heater per 20 sqm needed
Alternatively :
optimized
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19850416&CC=US&NR=4511787A&KC=A#
1 Sibert heat pipe/ tube caloric 2000 Watt ( not 2x 1500 W comparison as in the publication written) caloric output ~ 4x Zhang heater
Sibert heat pipe/ tube input :
A. not 1 but two - seriell connected - Bei Wei Wu lamps
B. with pipe/tube inside coating
C. and "power controler" :
optimized 200 electric Watt input  from before 660 W for 2000 Watt caloric output "aequivalent"
Endconsumer price estimation : 100 Euros max.the pipe/tube heater and 50 Euros the " power controler"
https://www.resoheat.com/   R.O.I. : 7,5 years
Only room heating related : optimized Sibert heat pipe/ tube R.O.I. : 1 year        150 sqm living area in Germany ~ 7-8 heat Sibert pipes/ tubes
Hot water generation :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130110&CC=US&NR=2013011125A1&KC=A1#
      [0010] with same optimation process ( lamps,connection,coating,controler)
Modern construction : https://www.3dwasp.com/en/3d-printed-house-gaia/
With the given insulation numbers I estimate for southern Europe : 500 Wp/20 sqm
https://www.patentauction.com/patent.php?nb=11044
= E. U.  2020 > 50 sqm NEARLY ZERO ENERGY BUILDING STANDART
+ Resonator/Zhang-heater = SOLAR PASSIVE/ACTIVE BUILDING STANDART ( also in Northern Europe)
For under 100 Euros/sqm construction costs. !
Next step : the under 50 Euros/sqm SOLAR PASSIVE/ACTIVE BUILDING STANDART
https://www.jovoto.com/projects/300house/ideas/12501?page=1&scope2=published&scope=prizes
+ wind generator/ Solar cell array : NET ZERO ENERGY BUILDING STANDART
for under 100 Euros/ sqm !
For 150 Euros/sqm : ZERO ENERGY BUILDING STANDARTincluded room air conditioning, warm water, electric appliances energy source " in situ " !
A.  ultra- low electric appliances energy need per day : 0,8 KWh + heat source ( wind/ solar)
      https://mtbest.net/energy_efficiency.html
B.   Before up to 18 KWh : intelligent and economic household up to 3 KWh per day + heat source
     https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.oeko-energie.de%2Fenergieberatung%2F
This is the official E.U.-"construction engineering" program for the next two dekades(- 2040) in execution ! :)
Water plant "in situ"
white water : Air2water/Sanakvo ( summer)/ fog&rain collector( winter)
Grey water to white water
https://www.jugend-forscht.de/projektdatenbank/computergesteuerte-abwasserreinigung.html
or Labuntog
https://www.google.com/search?q=ernesto+labuntog&ie=utf-8&oe=utf-8&client=firefox-b-m
or https://www.aqsolutions.org/
Sanita/closet : no black water producing
but " compost toilet" like modern society life culture in Sweden
or canadian (re)-local/locate-able flexible lifestyle habitations
https://www.google.com/search?q=habitaflex&ie=utf-8&oe=utf-8&client=firefox-b-m
How much easier and cheaper can we 2019/2020 construct an autonom building ?
Several Prototypes
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.zeit.de%2F2010%2F20%2FTechnik-im-Trend-Wohncontainer
http://www.mobilchalet.de/
https://www.ecocapsule.sk/
https://www.wohnwagon.at/
::) Budget 300 US$ : https://www.jovoto.com/projects/300house/ideas/12769  ::)
Good information source : https://realgoods.com/
                                                https://www.motherearthnews.com/
Last but not least : in development
indoor/outdoor room air ventilation with heat recapture +/- 150 Euros for 20 sqm living area
with ultra-low consume vent-motors and near 100% recapture efficiencyincluded :
https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=202011002985U1&KC=U1&FT=D&ND=3&date=20110829&DB=EPODOC&locale=en_EP#
Heat pumps with average C.O.P. > 10
compressor and electric motor improvements
Compact air ventilation with waste heat recuperation and integrated heat pump : British company IMI ,Award 1995 = 2019 " open source" technology = 75% cheaper
https://passipedia.org/basics/the_passive_house_-_historical_review/poineer_award
Germanys' first academic "Solar (Passiv) House" Building Construction Pioneers: "
                                       1988 Hopfgarten  Thueringen/ ex-GDR
                      By french Michel - Trombe wall ( ANWAR) experience used
                                       1988 : BoAdamson + Wolfgang Feist
         https://www.google.com/search?q=bo+adamson+passive+house+portugal&ie=utf-8&oe=utf-8&client=firefox-b-m
                                       Mr.Prof. Feist "sponsor" : https://isorast.de/
                                             https://de.m.wikipedia.org/wiki/Solararchitektur
The 2019 building construction architects and construction engineers are planning and errecting  with " open source"- technology !
What has been 1990 " new granted air ventilation/ heat pump/ double glazed window + profile  patent ware value ~ 1500 DM/ 750 Euros/sqm " as "Solar Passive House equipment"  is  2019 now by " open source condition" maximal 200 Euros/sqm "Baumarkt/home depot" market price worth !
Fob factory and buying with group rebate : +/- 125 Euros/ sqm
About the "construction velocity" and worker paying :
https://m.youtube.com/watch?v=ez-M8wHX4Wk. "2000 sqft in 1 day"
or
http://contourcrafting.com/#      "184 sqm in 1 day"
Only bad organized architects and construction engineers need more time
For ultrasonic house demolition/destruction to powder we need today less minutes : with the appropriate tool
https://patents.google.com/patent/US5463914A/en
for 3d printer relative easily to   construct : in plastics or metal
The micro-motors :
https://www.google.com/url?q=http://www.schillergy.com/pdf/schiller-energy.pdf&sa=U&ved=0ahUKEwivs6Pp1orkAhVlSxUIHZihCeEQFggLMAA&usg=AOvVaw3LubHebN4wNDEFxtg_rfyy
When a nominal 1000 W/3000 RPM Schiller electric motor weights 1 Kg
( alibaba /aliexpress commercial selling worth : 75 Euros)
how much weights a 12,5 W/18000 RPM micro- motor ?
1000 W/ 3000 RPM : 1 Kg
12,5 W. / 3000 RPM :  0,0125 Kg = 12,5 grams
12,5 W/   6000 RPM :                          6,25 grams ?
12,5 W/ 12000 RPM.                           3,125 grams ?
12,5 W / 18000 RPM.                      <  2,1.    grams. ?
2,1 grams/ 1000 grams : material based selling price ,alibaba. ? 0,16 Euros ~ (2,1/1000)x 75 Euros
4 micro-motors + gear transmission for 25 Euros endconsumer price  ?
3000 RPM ~ 20000 hours lifetime bearings
18000 RPM ~ 3750 hours lifetime bearing
Advantage : not outdoor temperature dependant like air-air-heatpumps ,similar ground heat pump
free energy = wind converter to hot water
https://www.google.com/search?q=wind+brake+hot+water&ie=utf-8&oe=utf-8&client=firefox-b-m#spf=1566135812319
Mixing resoheat/ wind brake :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001020&CC=FR&NR=2792258A1&KC=A1#
Assuming low weight car transmission ~ < 100 pounds
and 4 x Schillermotor ~ 750 Euros  endconsumer price for the " wind brake"- gear drive
+ hot water chamber costs
Assuming 12 KW cinetic output and 2,5 KW electric input : +- C.O.P. 5
2 KW ( 4x nominal 500 W) electric motors with "inrush current limiter" and seriell starting process
for the later https://patentauction.com/patent.php?nb=11462 or Dr. Imris generator efficiency improvement
and conventional buildings get for less than 5000 Euros " Solar Passive house/ Nearly Zero Energy Building"
heat consume efficiency : 30 Euros/sqm modernization costs
http://www.freel.tech/
https://patents.google.com/patent/EP2477200A1/fr
https://solarimpulse.com/companies/freel-tech "proof of concept 2009"
https://patents.google.com/patent/CA2773393A1/en
20000 Wh = 20 KWh / Kg
        100 US$/KWh costs
        2000 US$/Kg. costs
        compared :
                                               https://patentauction.com/patent.php?nb=13385
        hybrid super capacitor
        10 Wh-20 Wh /Kg
                                                             1000 Wh= 1 KWh/ 50-100 Kg
        125 US$/ KWh
                                                      125 US$ /50-100 Kg = 5 US$  - 12,5 US$/Kg
                             2000 US$/ Kg freel. tech versus  5 US$  - 12,5 US$/ Kg " hybrid super capacitor"
                             fast. to   200 US$ / Kg freel.tech  net cost decrease potential  ?
                  "costs" versus consumer "market price", not 1000% but probably 10000% margin sector !
2015 : 15 K€/KWh super capacitor
https://www.google.com/url?q=https://hal.archives-ouvertes.fr/hal-01195523/document&sa=U&ved=0ahUKEwjOq7LG8IzkAhVoSBUIHRAWDxYQFggkMAo&usg=AOvVaw2wdxHOQSL7gMdF-8Qy7GaJ
2017 : 20000 US$/KWh super capacitor
https://books.google.pt/books?id=MXF_CwAAQBAJ&pg=PA148&lpg=PA148&dq=capacitor+KWh+over+lifetime&source=bl&ots=bG3jcsYGc2&sig=ACfU3U1Tt2cxnpc81SIKiCKBU77iU9N9lw&hl=de&sa=X&ved=0ahUKEwiriZSz8ozkAhUGZlAKHSU1Bcg4ChDoAQgNMAE#v=onepage&q=capacitor%20KWh%20over%20lifetime&f=false
2018: 25000 US$/7,1 KWh
https://www.solarquotes.com.au/blog/arvio-supercapacitor-battery-review/
Surplus energy storage :
http://circuminvent.com/low-cost-thermal-battery
10000 US$ for 3,5 MWh means less than 3 US$/KWh storage capacity costs
3 US$ /365 charges per annum / lifetime : cheap
