New Tech
Started by lancaIV, July 12, 2013, 05:35:09 PM
Benchmark :
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fwww.zeit.de%2F2010%2F20%2FTechnik-im-Trend-Wohncontainer
https://www.wohnwagon.at/
http://www.livingbox.it/en/info.asp
https://www.nanolivingsystem.com/
Prof. Peter Huebner "Casanova"- Modul ea.  13 sqm   3x ~ Starter family. -38 sqm        6x expanded family -78 sqm
https://www.plus-bauplanung.de/
Hundred and more international architects construction designs for the 7500 USD/32 sqm ready(-64 sqm Option)
Elemental- social construction- project :        http://www.elementalchile.cl/en/
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.n-tv.de%2Fwissen%2FWie-man-Raeume-klimafreundlich-kuehlt-article21241492.html
" kids for future" + " kits for future" :
Heat pump : heating + cooling function  = reversible thermo(- cryo)dynamic cycle
Fraunhofer- Institute efficiency study conventional heat pump : 2,5 x C.O.P. thermic/cryo units per electric unit
        " inverter"-                            3,5
              Technical and physical "Standart" for room cooling :
              actually commercial the given "Fraunhofer study"-numbers for cool air conditioning
              3400 btu ~ 1000 Wh caloric change by 400 Wh average electric power
             " retro- fit kit "
              waste dynamic cycle heat to electric : conventional C.O.P 2,5 to  new benchmark : 4,5
             400 Wh - 180 Wh average heatelectric recuperation : 1000 Wh/220 Wh ~ C. O. P.  4,5
              electric motor single winding to double winding refurbish :
            400 Wh to electric 300 Wh less 180 Wh heatelectric power recuperation =
           300 Wh- 180 Wh = 120 Wh
          1000 Wh/120 Wh ~ > C.O.P. 8
             2019 "Industrial Standart"
            For new production heat pumps the minimum mandated  C.O.P. for ambient cooling :
             from C.O.P. 8 to C.O.P. > 10 by
            low friction and power saving compressor technology :
           https://web.archive.org/web/20160211000054/http://www.solterrah.com/mech-clean-energy.php
           http://www.eats.ltd.uk/heating_cooling.html
           From conventional 400Wh electric average input for 1000 Wh caloric inter-change( = pumping) to :
          400 Wh to
          300 Wh double winding motor to
          255 Wh low-e compressor motor efficiency less
     -   180 Wh heat-electric recuperation :
         75 Wh net electric consume for 1000 Wh caloric/btu inter-change
         1000 Wh /75 Wh =   > C.O.P. 12,5
        C.O.P.   2,5/12,5 = 0,2 or 80% less
        = 100% Kyoto conference result and declaration : 1990- 2050 : -80% GHG emission
      q.e.d  ::)
       Conventional heat pump efficieny :        400 Wh
       with Catalan Halbach array motor :        200 Wh  ?
      with power saving compressor :              170 Wh. ?
       Less waste heat recuperation :             - 180 Wh. ?
       New STANDART.                                         -10 Wh ?
       Cooling and surplus energy generation
      Instead Catalan motor refurbishable " Meta C"- technique or Dr. Imris capacitive winding or Lam Dat
     Net zero energy cooling : also possible by solar cell/Turbine assistance
Surprising! ! The re-thinking and his decision :
https://judbarovski.livejournal.com/    his " the manifesto"
http://judbarovski.blogspot.com/2019/08/ethanol-as-fuel-its-production.html?m=1
But to be as flexible as he is :
6 lt. /100 Km conventional fuel consume  car
Stupak fuel economizer - 30% fuel consume
https://patentauction.com/patent.php?nb=8081
Granstroi : Arakelian fuel process - 87,5% CO2
https://patents.google.com/patent/EP2690158A1/de
+ emission filter : 50% average CO2 recapture
https://patentauction.com/patent.php?nb=14020
- 95% CO2 emission and CO2 reuse
Whom 95% less emission are not enough : hybrid kit
https://www.google.com/search?client=firefox-b-m&q=manfred+sonntag+hybrid&oq=manfred+sonntag+hybrid&aqs=heirloom-srp..0l1
Ic- engine versus electro, CO2 related :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fedison.handelsblatt.com%2Ferklaeren%2Fvergleichsrechnung-so-viel-co2-sparen-e-autos-gegenueber-verbrennern%2F22654278.html%3Freadon%3Dy
Modified Stupak + Granstroi + emission filter ic-engine car ~ electric car + renewable electricity ( Oeko-Strom)
