New Perm Mag Engine Design 1.5 : 1 Ratio (work from magnets)
Started by Floor, August 05, 2013, 08:36:48 AM
Floor
@conradelektro
Here are the first sets of measurements.
There are no graphic representations yet, and there are yet more measurements to take.
It was a lot of work
Thanks again for your time.
(and your patience)
                                    Cheers
                                         floor
conradelektro
@Floor:
Great, the measurement accuracy is better than I expected (little difference between all five measurements). I think that three measurements (instead of five) per position or weight are enough.
Unfortunately it is not clear to me which movements you measured.
I came up with a "numbering" or "naming" of the different movements of your machine in the attached document (which I already attached in an earlier post). May be we can stick to this "naming" of the movements: set 1), set 2), set 3A), set 3B), set 4A) and set 4B).
You can of course define an other "naming" convention.
Take your time, there is no hurry.
The 22° jump: may be it means that the neccessary force (weight of the bottle) is less at 80° than at 68° or 90°. You could move your machine to 80° by hand and then find a weight that holds it at 80°?
Greetings, Conrad
Floor
@conradelektro
As yet there are only 2 sets measured, the largest ones.
RO = rotating magnet
SL = sliding magnet
Both of these sets of measurements, were taken with the magnets in place.
RO was measured while SL was in close proximity.
SL was measured while RO was parallel to SL  "0 degrees off"
Floor
The above PDF file "TD measurements corrected 1" undoubtedly still contains errors.
Floor
@conradelektro
Thanks for the input / suggestions.
Yes we will investigate the "jump" in later measurements.
My apologies for the sloppiness, errors and redundancy of some of the previous uploads.
Please find the carefully produced and attached PDF file for your review / checking / entertainment.
                          PS
                           Other people's reviews, error checking and will be appreciated.
                           For the convenience of others, please include a PDF format version for lengthy input.
                    Cheers
                           floor
