Magnetically Imbalanced Wheel
Started by Hope, August 09, 2013, 01:58:22 AM
Hope
Quote from: Hope on August 10, 2013, 09:49:23 PM
Ok,  finally I have it loaded.  But it is in downloads section under Imbalanced Magnetic Wheel.
http://www.overunity.com/downloads/sa/view/down/537/   this link will get you the drawing.
FatBird
Sorry, But it looks like "CLEAR AS MUD" to me.  LOL
Hope
Farmhand
I think I know what you mean Hope.  :) Interesting idea. I think the confusion comes from the way you drew the flexing magnets.
Do you mind if I try to make a drawing so you can see if I understand you.  ;) I think I can do it.
I must go to be repaired in the hospital as well, I get my assessment on wednesday,
with any luck I won't need an operation. Good to hear you are back into life.
I should be back in no time I just need a few screws and a new disc in my neck.  :-\
Usually a quick fix. I think I can make a drawing and then you will see if I "get" you then.
Maybe it could be done with a slightly different way to "move" or flex the rods/magnets.
Flexing may well be best though, when I think about it.
Wishing a good recovery for you.
Cheers
Hope
Any contribution is quite welcome Farmhand, thank you.  I did consider to place the magnets on joints that shifted but opted for a simple prototype design.  My double magnet circle showed it did add the weight correctly with flexing rods.
The power can be scaleable and plotted with existing formulas, which is of course due to the wheel following the known laws of physics.  The only twist is using magnetic fields to cause physical movement and a continuing imbalance of the device.
