a.king21
No-one on this thread is claiming the device works, but I disagree with the idea that it cannot work. I know Melnychenko (who Kapanadze states on occasions as being close) has a patent which I machine translated.
The gist of Melnychenko's patent is that a  transmitted signal  picks up static from the earth's electromagnetic field and this has a FE effect. Well, the  L1 of a transformer is also a transmitter, so I can see the possibility of a new source of energy. Nothing OU about it just FE, which is just as good.  OU is impossible, because you can't have more than 100%  of anything by definition.
Kapanadze also told me that his secret is "so simple you will laugh" (and then he cheated me and my partners, of course.) The Barbosa stuff qualifies as a suitable effect to substantiate Kapanadze's comment.
Even if something does not work, it is worth posting, because it saves useless "replication attempt" time.
Science takes no sides. It's just science.
And remember, we only have to be right ONCE!
Bruce_TPU
Quote from: a.king21 on August 18, 2013, 11:42:49 PM
If you know the answer, then why don't you tell us. And what has this to do with the simple electron trap from the earth?
It has EVERYTHING to do with the electron trap.
Figure it out.  It is not hard!
Cheers,
Bruce
"Energy from the ground" is a common misconception that comes around every now and then.  Even the notion that a supply of electrons from the ground "supplies the current" for the "extra power" in the circuit does not even make any sense.
No circuit needs electrons from the ground to support higher currents, none!  All circuits are closed-loops that the current circulates through.  Connecting a "ground pipe" to the circuit will do nothing.
Here is the crux of the matter:  Somewhere in the circuit there has to be a mechanism to up the pressure (voltage) to get the current to flow.  That device that ups the pressure needs a power source to run.  Any connection to the ground is not a power source in any way, nor is it even needed as explained above.
So, you are back to the question:  Where is the power source that feeds the device in the circuit that ups the pressure to create the current flow?  Somewhere in the circuit the voltage goes up, and that device that ups the voltage does not do it like "magic," there has to be some kind of mechanism that takes some form of supplied power and converts that into the upping of the voltage.
There is "pump" somewhere in the circuit to make the current flow, there simply has to be.  Where is it and what is it?  What kind of power source connects to the "pump" and where does the power come from?
QuoteIt has EVERYTHING to do with the electron trap.
If by the "electron trap" you mean the ground connection, that's a non-starter, see my previous posting.
We are all waiting for you to spill the beans Bruce.
baroutologos
Quote from: Bruce_TPU on August 19, 2013, 12:04:14 AM
Cheers,
Bruce
Figure it out huh? You are the one supposed to have assembled a OU device (called TPU) and solved the energy problem?
Now you give hints and tips?
