Dave45
Everyone is working up a good ground connection right  ;)
8 ft rod with 10 ga stranded, a water pipe may be better  :-\
totoalas
Quote from: totoalas on October 06, 2013, 05:44:36 AM
From the video
2 transformer primaries   1 and 2 in parallel and connected to 220 v ac supply
Tr 1 and TR2 secondary  one turn each on series connected o the primry one turn to close the 6 mm copper single wire
the output of TR 3  is connected to load lamp
Battery cable is an alternative
for the new version using earth
dc to ac inverter to the above circuit
TR3 output one to load   and the other to earth
this is my interpretation  correct me if im wrong
Dreamyear has YT like this
Update  from 1st circuit
Using 3 identical transformers   220 v  to 24 v ac   10 watts        and a 220 v ac 50 hz 10 watts bulb
Input current   0.4 amps       output current to lamp is 0.2 amps
Will try to modify the  24 v ac coil into a stranded  6 mm  wire   tomorrow
forest
Is there any simple method to measure ground reistance ? I know there are specialized meters but I couldn't afford buying one....
NickZ
  Ground resistance can be improve by imitating what TK showed in his back-yard video, by adding salt water to the grounding rod and surrounding areas. Or if you have a water well, the ground can be inserted into it. Which is similar to what Akula 0083 is doing, instead. But, he is also using a thick 10 meter long ground cable, to get to it, which is not an option. Shorter ground connections won't work, at least that's what he said. So, it may be acting as an antenna, as well as a ground.  Interesting ideas that still need some testing, by us.
totoalas
we add salt to galvanized plates / earth rod  in our 11kv substation
