earthenergy
Quote from: Schiko on December 31, 2013, 12:45:06 AM
Just want to remind everyone that the device has evolved, the "Captor" now also capture electrons from the air.
So not only is the earth leaving things.  ;)
And this is a little more complicated.  ;D
In my opinion all these devices work on the same principles, if you discover how one works, will know how they all work.
And it should be a very simple thing indeed, for all the masters in the art, ancient and modern say the same.  8)
Agreed... I believe the capture of the electrons is just a part of what is going on. I think the real essence of this breakthrough is that a gateway is being opened into the ether, or into the dimension if you will, that  actually supplies a magnetic field with it's power. Look at a permanent magnet. One shot of electricity into a magnetic material and you have a circulating flow of electronic activity that keeps going and going and going.
In trying to replicate the Barbosa/Leal device it may be helpful for people not to not focus solely on the electron capture, it is probably only part of the process, there is probably energy coming in from somewhere else. Floyd Sweet tapped into the ether without a ground, so did Marks, and I believe EV Gray as well. Tapping into the ether with a pulsating field would seem to be what is taking place. It would also seem that the voltage is somehow sourced through the primary and the current is somehow sourced from the closed loop secondary.
Someone should be able to nail it soon enough, if not, we all wait for the Barbosa/Leal device to hit the market. ( If they are not taken out first that is, it remains a possibility as long as no one has replicated. They also seem to want to make a killing on the device at 5k a unit, so they may get bought off right away)
I believe they have the real deal, the best one yet, the cheapest and simplest to build, and one that is ready for implementation.
FatBird
The PDF Patent is below for downloading.  This is really STRANGE, because I "assumed" that wires 4 were the output WIRES.  But after I re-read the patent several times,
he keeps referring to THE LOOP.  So I "assumed" he meant the word loop INCLUDES the Load.  But apparently NOT.  So if I am reading this right, wires 4 are SHORTED TOGETHER
and together they form THEIR OWN LOOP in the Core, AND is 1 wire of the output!!  So if the Wires 4 are SHORTED to form 1 Output Wire, where is the OTHER OUTPUT WIRE??
Below is some of the patent wording I copied out for this post.
1.  Here, the earth wire 5 is wrapped around the continuous loop wire 4, feeding it additional electrons captured from the ground. The ends of wire 4 are connected together to form the loop,
     and that connection also forms the positive side of the output (where a DC output is being produced). The magnetic field produced by the current flowing in wire 3, acts on the electron flow
     coming from the earth, but it does not provide any of the electric power flowing in wire loop 4.  The current flowing in wire 3 can be tiny, without affecting the power output.
2.  The earth wire (5, shown in blue) which is merely wrapped around wire 4 and not directly connected to it as the electron-transfer link is by induction.  With this arrangement, the current
     circulating in the closed loop wire 4, attracts more electrons from the ground, flowing through the wrapped connection of wire 5, into wire 4, increasing the current flow there by a major
     amount.  Wire 3 (input) can have an alternating voltage applied to it in order to get alternating current in wire 4 (output), but understand that the current flowing in wire 4 is not the result
     of the current in wire 3.
earthenergy
But after I re-read the patent wording several times, he keeps referring to THE LOOP.  So if I am reading this right, wires 4
are SHORTED TOGETHER and together they form 1 wire of the output!!
[/quote]
In the latest video they appear to connect the ground to the bare copper of the closed loop. It must have proven to work better. (wondering why they didn't test that before filing a patent)
Yes you can get an output connecting one lead of the load to the closed loop and one to either side of the primary. I have done that and it will light a bulb, the ground must be connected, but I do not see any magic happening. It appears to be current going to ground from the primary. I may be missing something though.
I have also been testing off grid with a square wave inverter. Their setup may now require pure sine wave as they talk about working with the hydro company rather than eliminating them. It also seems that their first success and demos were with a battery/rectifier/inverter setup and now they are plugging into 220 from the wall instead, so that seems out of place.... is the single phase 220 pure sine wave being supplied to the primary where the very high efficiency begins to happen?
Also beginning to wonder if the primary coil and/or the closed loop coil have to be tapped midway/halfway
FatBird
The SMALLEST unit they sell is 12,100 WATTS, and weighs ONLY 4 Pounds (1.5 KG).
That's a paradox too because I would think the box would weigh more than that.
The biggest one they advertise is 282,700 WATTS.
That could run a small TOWN.
http://energiauniversal.eco.br/
earthenergy
Quote from: FatBird on December 31, 2013, 07:00:11 PM
The SMALLEST unit they sell is 12,100 WATTS.
That is the small unit on the table in the 7 minute video, the one that powers the bank of 6 one thousand watt bulbs with an 220 volt input of .1 amp which is about 22 watts!  Output is 220 volts, 26 amps. The transformer must be very small as the weight of the unit is 1.5 kilos. Hard to believe... but I do not believe they are con artists.
What is the impossible dream though, is that they would be able to sell a $29.00 transformer for $5.000.00 dollars. It is a pipe dream. People will build their own unit once the secret is known. The device can never be kept secret, unless it is suppressed now before it gets out.
