nelsonrochaa
Hello, I would say that after making tests with 12v dc without being connected to the electrical network realized that something strange was happening because the same circuit in my opinion behaves as a "joule thief". I observed that with only one pulse one 12v battery the voltage gain would quickly close to a capacitor 70v.
I repeat the circuit is not connected to the mains.
I'll try to make a circuit to pulse dc current.
I'm not here trying to prove anything because it is all in the name of science :)
The electric installation of my house has all electrical and fire protection if the phase is connected with the earth however the circuit works without the differential protection shoot.
I think that the patent does not specify how exactly is the circuit.
I will continue with my tests and will post new videos soon.
thank you
Farmhand
If there is a working RCD (safety switch) installed at the meter box if a current mismatch between the Active (phase) wire and the Neutral wire of more than 30 mA occurs as shown in the video, then the RCD will trip open. That is what they are designed to do to
save lives, if it doesn't then it's faulty or not installed correctly, or the connecting of the phase to ground does not cause a current
mismatch of 30 mA or greater. In the video there is 2.4 amps on the phase and zero on the neutral, but there would be some due to the 40 or so watts measured. Just the meter probably cannot read that small of a current.
Are you sure you are connecting the Phase and not the neutral to ground ?
Video clip showing meter fooled.
https://www.youtube.com/watch?v=wbNvUZT4NC4
It is also possible to use an "inline" RCD (safety switch) I have one and use it, cost only 25 dollars or so. They should protect the
user from electrocution between Phase and ground when using grounded neutral inverters and detect when a mismatch of current between the Phase and neutral occurs.
Using an isolation transformer without the output neutral connected to ground won't work as the isolation transformer cannot exert a potential difference between the isolation transformer output and the ground, so no current flows through the ground and virtually no output will be got from between one leg of the isolation transformer and the ground. Another pointer to the grid supplying the energy.
nelsonrochaa
greetings, after doing some tests with pulses 12v dc transformer barbosa as thought behaves with a joule thief.
I have no oscilloscope to analyze the output but it would be interesting to observe the wave.
I made some changes in the original configuration because as I said the patent for this barbosa not tell everything.
Who would bother to patent something that is a fraud? ;)
Thank you for your comments.
https://www.youtube.com/watch?v=LYbMfbeQMZ4
leo48
I live in Italy and the meter set by the company making the distribution of
electricity  is electronic type with permanent digital connection with the mainframe
electric company and also has the built-in 'switch for maximum power and
differential of the earth, not by-passable and every malfunction is noted
on the bill as attention.
Therefore it is impossible for me to do these tests ...
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
nelsonrochaa
I live in portugal and in my home i have the same electric protection .
