Proof of Overunity From Magnets Fixture, No Negative Work Aspect, LaFonte
Started by gammarayburst, September 05, 2013, 03:00:53 PM
gammarayburst
Quote from: timechicken on September 16, 2013, 07:15:11 PM
Ah yes, thanks for clarifying that, don't know what I was thinking.
Has anyone constructed a working unit demonstrating this effect in full? I watched all the videos I found, but in every one of them work was done by hand and it's not intuitively clear to me how much there is that the eye doesn't see (like resistance to moving the magnet in each stage). I'm baffled by this as must be many others!
I promise you that if the magnet is not touching the bars and has like a .003" air gap on each end then you can move it with a feather. I promise, promise, promise.
norman6538
Quote from: gammarayburst on September 19, 2013, 05:49:35 PM
Butch, In a previous post
I didn't find it that easy when I made the measurements with a neo on a matchbox car so I assume you are exadgerating a bit because a feather doesn't even weigh an ounce. So the bottom line is in the measurements. If the measurements demonstrate this then the embodiment will soon follow. So if a small force can be used to release a larger force then
we have it except that the embodiment has to be reset to repeat the cycle again. That has been my frustration numerous times.
  Norman
gammarayburst
Quote from: norman6538 on September 19, 2013, 07:59:30 PM
  Norman
Your car had a large amount of rolling friction in the wheels and axles. It's this simple, eliminate eddy current drag, float the magnet with .005" air gap so the forces are equal but opposite on the magnet poles and there is nothing to cause drag. It will just float along like a balloon.
norman6538
Quote from: gammarayburst on September 19, 2013, 09:13:28 PM
Butch you could actually demonstrate OU if you could demonstrate and measure this concept.
I was not quite able to do that. Then your horse would be out in front of all of the other horses.
Norman
gammarayburst
Quote from: norman6538 on September 20, 2013, 07:42:58 AM
Norman
Norman, Mark built all our test fixtures and he is no longer doing that. He is working on a project he took on for himself. I have no resource at this time for test fixtures. The ones we built in the past show that it works. It has to move with no drag because with eddy current drag eliminated and equal but opposite forces on the magnet poles and a very small air gap at each end (.003" to .005") the Pseudo Solid effect takes over and the magnet is just floating. It works, I have felt it with my own hands. I will draw a simple test fixture if someone should want to prove the effect.
Butch
