Magnetic fields within a toroid inductor.
Started by tinman, September 11, 2013, 10:01:30 AM
Dave45
I really dont think its heat causing the effect but even if it is the ice freezes solid and it looked exactly like a tornado in the container.
I used a plastic container, the ones they use to cook pasta by adding boiling water. Something of interest, if the coil is energized it will not crack the container but if the coil is not energized more than likely the ice will bust the container.
Another experiment I did, I know some dont believe in the ether but check this out.
I took a transformer put it in the container covered the container in copper screen wire basically creating a Faraday cage,(I lined the inside of the container) then I froze the container without the transformer being energized, it busted the container and ripped a two inch slit in the screen, I got kindof discouraged because it ripped the screen but I decided to energize the trany anyway. I left the cell in the freezer and energized the coil and checked it about an hour later, there was a jagged line from the slit in the screen leading to the tranny that looked like a lightning strike, the jagged line had not made it all the way to the trany this tells me the line was coming from outside the cell and not from the transformer. At the time I really didnt realize what was happening I thawed the container and took everything apart without taking any pics but as I thought about it later I wished I had taken pics. Does this prove the existance of the ether  :-\ not sure, I was planning on repeating the experiment but havent done it yet.
Here's a pic of one of the setups I used before being froze.
Dave45
I have froze a permanent magnet and the field is there just like with the coils, there is a field besides the magnetic field, there are two fields the magnetic field and the electric field. If you think about it the electric field runs 90 degrees to the magnetic field and this is exactly where this field is, right where its supposed to be.
Guys Im no electronics expert and not the sharpest tak in the shed but it doesnt take a genius to realize this needs to be explored in more detail.
Dave45
Here's a permanent magnet froze in ice, this is with tap water so its not as clear as with the bottled water. Notice the field is not at 90 degrees in relation to the magnet but more like 60 or 51 to be more precise.
Dave45
Check this out, the camera pic shows a curvature in the ice in some of the pics I took but there was no curve there when taking the pic..
Dave45
