The EM Sucking antenna
Started by Tesla_2006, August 11, 2006, 10:38:09 PM
Xaero_Vincent
Read the PDF about Dr. Oleg Jefimenko, who powered an electrostatic motor with an earth-field antenna. It is basically a wire with a sharp tip connected to a balloon. Dr. Jefimenko was able to draw 70 watts of free power to run his motor from a 1200 ft wire in the sky.
According to here:
http://jnaudin.free.fr/html/pftm2.htm
Upto 7kW could of been harnessed if the rotor could spin at 120,000 RPMs.  ???
Its certainly an interesting alternative or compliment to solar power. The issue would be whether or not you'd be permitted to fly balloons hooked with high-voltage wires to houses. The balloons cannot interfere with air traffic (an obvious problem once masses of folks do this). It might be feasible to hook an array of 50-100 ft long poles in series on your property.
The neighbours might complain about large poles so make sure you live in a rural area.
the_big_m_in_ok
Quote from: the_big_m_in_ok said:
quote]
Patent #2,814,242   Powering Electrical Devices with Energy Extracted from the Atmosphere
http://www.google.com/patents/about?id=CcdUAAAAEBAJ&dq=patent:2813242&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=
There are a whole lot more of patents like these at:
http://www.overunity.com/index.php?topic=7832.0
More additions to that particular thread can be added later by me or anyone else.
--Lee
triffid
yes big m,thats the crump I was talking about.The diagram of the radio is where he uses power from radiowaves to operate (power) the radio.The other two diagrams have different loads.Triffid
the_big_m_in_ok
Quote from: triffid on July 30, 2009, 11:00:35 PM
I just found this on the Web:
http://peswiki.com/index.php/OS:Radiant_Energy_Antenna_System
Goes in well with this thread and my thread on patents(  http://www.overunity.com/index.php?topic=7832.0  ).
not_a_mib
EM sucking antenna technology was apparently marketed in the 1980's for TV reception rather than power generation.
http://www.milk.com/wall-o-shame/dish.html
This product clearly sucked!
