Parallel Core Generator
Started by vineet_kiran, November 18, 2013, 12:34:08 AM
gyulasun
Quote from: broli on November 18, 2013, 04:06:40 AM
Try to work with a much longer solenoid than the length of your magnet. You will see interesting things happen.
Hi Broli,
A question if you do not mind: if you make the long solenoid into the shape of  a toroidal coil (using wood or plastic ring as the holder of the wire turns), then do you know whether the interesting things can still happen?
By the way, what are the interesting things happening in the case of the long solenoid?  Yes, I am curious...  8)
Thanks, Gyula
d3x0r
My guess is that the pulse will only show at the start and end of the coil, and inbetween will be a net 0 as the electrons move in one way and then the other none.
So extending into a toroid is a net 0.  But you could spin any magnet inside a toroidal coil and see...
d3x0r
vineet_kiran
@Gyulasun
Thanks for the nice videos.  Anyway let us not bang the open doors. Let somebody else enter the house straight away.
I had made one more design to avoid lenz's forces and posting it in a new thread (Single coil Generator).   Kindly have a look and share your thoughts on it.
Regards,
Vineet.K.
gyulasun
Quote from: vineet_kiran on November 18, 2013, 12:17:46 PM
...  Anyway let us not bang the open doors. Let somebody else enter the house straight away.
Hi Vineet,
Although I meant "you are knocking on open doors",  I just do that: I share my views when at all I can or when it is appropiate, it does not fully depend on me.  Several 'big guns' just keep the door closed and might open it for money but even so you have to be very careful to get what you were promised to get...
Gyula
