Parallel Core Generator
Started by vineet_kiran, November 18, 2013, 12:34:08 AM
vineet_kiran
Eliminate lenz's forces using parallel core
d3x0r
vineet_kiran
@d3x0r
Thanks for the link.  That (JLN) website is last updated in 1999.  Since then has anybody tried to build it?  Is it self sustaining as claimed in the website?  I think this is a very interesting principle but why he has used copper tube as core material and not magnetic material? (laminated iron core)
Vineet.K
Try to work with a much longer solenoid than the length of your magnet. You will see interesting things happen.
gyulasun
Quote from: vineet_kiran on November 18, 2013, 12:34:08 AM
Hi Vineet,
You are banging on open doors... ;)
See these videos done by Bedini and especially the first one shows the same setup you propose with scope shot across the coil and he also says it is Lenz-less... He calles this kind of setup as zero force motor.
first video:  http://www.youtube.com/watch?v=3kpDMMcNQxc
second video: http://www.youtube.com/watch?v=4TICXxP1jI4
Unfortunately he has not returned to his motor setup since then (not yet on his new forum either) so the best you can do is to replicate. I do think that Lenz law manifests in the coil's ON time moments because a closed electrical circuit exists between the supply source and the coil but due to the orientation of the coil this effect is minimal (it could be checked easily by monitoring the input supply current to the motor when running and load the motor shaft mechanically).
So yes, such design exists and I also think it is worth tinkering with.
One more thing,  I quote from your PDF file:
"If multi cores are used, the individual cores should not be joined to form a loop as in the case of a conventional generator since fluxes produced by individual cores cancel off with each other and you will not get any output power."
If you watch carefully the second video, then (unless I am mistaken) you can see several short coils wound on a toroidal former (not known yet if the toroidal former is only an air cored bobbin or it has short individual cores inside just under the short coils). Nevertheless, I agree with your statement, those cores should not be made to be a closed toroidal core shape.
Greetings, Gyula
