Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
alan
Quote from: WTF on February 10, 2014, 02:16:13 AM
LOL
If he is a BSer don't you think this device is a strange thing to imagine, as I thought I had a very wild imagination but I wouldn't of thought of a device such as this?
If it is an alien, why won't he just land. Why has the "alien" an arabic name, the same name as like Assad?
Why are they so interested in religion and spirituality?
Imho it's a demon, which I know for a fact are real. :)
For we wrestle not against flesh and blood, but against principalities, against powers, against the rulers of the darkness of this world, against spiritual wickedness in high places.
Ephesians 6:12
WTF
This is now complete, all the crystal wires are in contact with the rod, I have tested this with a meter and this device doesn't work.
Hope
Quote from: WTF on February 05, 2014, 03:06:22 AM
The smaller the hole the less damage there will be when the bit comes through the other side, also I might be able to fit more holes than 4 which could increase performance.
Bashar did say touch and penetrate, now I don't know if he meant the wires should touch the outside of the crystal or that as the wire penetrates the crystal it should touch the sides or maybe both, but just in case I will do both.
When I drilled about a centimetre with the 1mm drill bit it seemed easy so I don't foresee any problems, after all the drill bit must have been designed to drill that deep without snapping.
When I do something I always like to do my best, I can't expect anything else, it's just the way I am unfortunately.
I have faith and lots of patients :)
if you place a tight fitting wooden rod through the center while drilling it should re-enforce the crystal can keep damage to a minimum.  If that doesn't work maybe a substance that does not expand when it is frozen placed it the center hole and frozen will keep the crystal better intact.
I have gotten side lined on my break down of the words.   Looks like you don't need them.
This Randy Mills energy demo to me is very important and I am not seeing any scam there.  Just a  lot of proofs and one heck of a lot of energy output.    WTF your last disk work is awesome.   Work has been demanding and I will be giving more time here as I can.
Hope
Bashar did state that the energy collected is of a yet unknown nature.  I really don't think any measurement device has been built to measure the output.  A little time and let your mind work on this project.  Your work looks great, revisions are normal in known sciences.  Expect that even more so in an unknown field.
Uniqorn
WTF, once again, very good work. And very important too.
It is a pity that it hasn't yet worked in its current form. But don't pack up quite yet. I've made a lot of gadgets in my time. My general rule of thumb for making any one-off device is 1/3 design, 1/3 build and 1/3 tuning. These proportions can vary wildly, of course.
You are at the tuning stage. I think you have got everything as right as is possible according to Bashar's instructions.
I can suggest the two areas to tweek would be whether or not the sharp copper axial rod should be touching, or just near the copper hemisphere bowls. Also, should the rim of the hemispheres be near or touching the spiral mesh? What we don't know it the required precision of these parameters, so play with these before reaching a definitive conclusion.
Considering precision, is the crystal ball exactly on the equator (the plane of the spiral mesh). Ironically, 'Bashar's definition of 'exactly' is not exactly clear! :-) Does he mean within 0.2mm, 0.5mm, or maybe 2mm? I think once you have exhausted playing with these final parameters and others you may notice, you can either pack it in, or try free-experimenting to your hearts content.
@Hope, It's true there could be many unknown phenomena produced by this device, but my reading is that it should be producing sparks along the lines of a Van der Graph HV generator. (Along with any other surprises!)
