Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Hope
Personally I would try two things,  first change the dielectrics (thick clear plastic disks u use now) to thin wax papers or thin nylon flexible cutting board and flip one of the disks over.  The N region of a magnet is thin so I would try to make the disks close.  Secondly, equal and opposite reactions is why I would try the reverse disk.  If energy is flowing in one direction it is also flowing in the other.
The close disks should be very centered unless the latitude and longitude of where your at matters.
If old Ed Leeds was working with this he might even align the copper pole north and south.  No one ever said how they should or should not be oriented.
If the wavelength of the sparks are very high then they will not be visible as in the extreme ultra violet range.
If all this fails to produce anything what would you think of a central disk of thin iron magnetized from the center edge and outer edge rotating (just spin by hand to check for output to hemispheres)  This is a way out there suggestion,  but who knows if Bashar gave us everything.
WTF
Bashar did say that the rod should be in contact with the hemispheres, but to make electrical contact I have to put a small amount of pressure on the hemispheres, maybe because the points are sharp so there's not a lot of surface to make contact.
I have tried putting metal over the hemispheres to close the gap as to bring it closer, maybe not the same as having thinner insulating disks but I thought I might show something.
The crystal ball where the wires come out are exactly in the centre of the ball, I made a kind of jig for the drill to make sure the holes were in the correct positions, and where the wires come out is where the wire net is.
Hope
When you say flip one of the disks over, I take it you mean the wax paper discs, is there a difference with these papers to what side you have it? Aren't they just paper.
Also I'm thinking how important the thickness of the insulating material is as he never mentioned the dimensions of it, but with the rest of the device he was very specific with the dimensions.
He also said if you get too close you would tap the energy, like to say you would be able to feel it.
WTF
I think another problem could be the connection between the rod and wires because a little movement can disconnect them, I tried putting holes in the rod but it made the rod very weak.
At the moment I'm trying to make some kind of spring mechanism, but if you have some suggestions on this that would be helpful.
WTF
I used the hot glue gun, so the wires are in good contact now, and being rubber its like a spring mechanism, but still not working.
WTF
Another reason this might not work is because the wires that go in the crystal need to be curved to continue the spiral.
