Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
guruji
Hi WTF great work regards. It would be good to consult with Bashar himself maybe he will give you more info.
Thanks
WTF
Actually I haven't given up, since I've I last posted I've made another wire net and crystal, with the new one, the 89 set starts from node 6 and the 55 set starts from node 4. Of course it still don't work but I have another plan, I've ordered a 60 amp adjustable power supply, so I'm going to power it up manually, one point at the rod and four points at the outer edges of the wire net, so the power should be distributed across all wires in this configuration, so that would be just over 400 ma per wire. I'm thinking by powering it up manually if this has any chance of working then I would get some effects, if I get nothing then I give up.
WTF
Quote from: Hope on April 05, 2014, 07:02:54 PM
Toon Town energy genset oh how funny WTF.
I am checking back with you on your great project work.   I still believe there is something to be gained by working through the kinks.  I always felt like the wire needed to be one continuous piece,  I mean if we were to follow natures build of the sequence it is continuous so why not that device?
Since all the wires are in electrical contact, isn't this like a one piece wire?
Hope
The contacts are,   but the path is broken.  The example of a Rodin coil shows even uninsulated wire does not short out due to a continuous path and pattern.   Also,  is this device not suppose to be about magnetics and not electrical in nature?  My "Just an Opinion" is that the device is used to separate the magnetic charges in a monopole fashion to be collected in regions NOT connected physically with each other.  Then for the very first time (in a known fashion) we can use just one charge to do work.   My "opinion" is that Leedskalin knew this and DID it also.  It is so simple if it works that way, then of course a device built like this COULD have been made thousands of years ago to do many things we are still trying to do with antigravity today.
But this is just as I see it.
But for certain broken strands of many wires is NOT the least path of resistance for vortexed charges traveling in opposite directions to travel.
Newtons law states  "Equal and Opposite", I agree.   Your the wind beneath our wings WTF,  thank you.
WTF
But Bashar did say each wire should be a separate wire.
I'm thinking that putting an electric current through the device could make a magnetic field as when you put a current through a coil it makes a magnetic field, and when you put a magnet near a coil it makes electric, so they are really the same thing.
