Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
falecf44
Wow, stumbled upon this thread after searching teleportation and vibrational properties of an object. I was looking to see if mainstream science had yet discovered that location is a property of an object. They haven't but early in this thread it was stated in that exact detail. I had heard that from Bashar and here I stumble upon a whole thread taking about some Bashar goodies!
I've read through the entire thread and am really impressed with what you guys have come up with so far, especially WTF. It seems as though you have been able to keep pretty much everything in proportion since you seem to have doubled the scale of the object. Am I correct there?
One thing that seems to stand out to me is where Bashar says the wire should be tightly woven. I notice that you did increase the number of wires quite a bit but the structure still seems to not be "tightly" woven. I realize that at the center it would be very tight and would get less tight towards the outer diameter in order to maintain the proper Fibonacci ratio. I'm not quite sure how this affects operation but I hypothesize that different weave tightnesses would collect different wavelengths of energies. Similar to how a Faraday cage blocks EM and other waves. The weave tightness, material and material thickness relate to the wavelengths blocked.
Idk exactly how one would weave the spiral as described but I do believe it is a critical factor. I've seen a couple replies where someone mentions a change and then says"well, its only x% difference". Well, if we alter all of these dimensions a few percent we are all of a sudden a large percent off from an ideal working unit.
My only suggestion for possibly making a better weave would be to make a jig on a CNC router. Essentially you would take your design (or preferably a tighter weave) and have the lines routed out slightly thicker than the wire diameter and about half as deep. You could then press the wires into the jig and weave them over and under each other to get your tight spiral weave.
Kalsum
Perhaps we should look at it in a different way. Bashar said that their ships traveled by changing the location variable of the vibrational equation of the entire ship. perhaps this is the means, lets ponder that idea. perhaps one would send a certain vibrational frequency through the spirals leading towards the top and bottom of the crystal sphere, then it would resonate along the spiral possible resonating anything in contact with the entire sphere, or it may create a "bubble of frequency with the size depending on the energy input of the vibration. Bashar encourages experimentation so it may just be part of the entire engine, just a theory to throw into the pool if you will. perhaps one could experiment by vibrating the spiral wires acoustically.
Hope
Hey all,  this device can effect time even .   Stan Deyo's anti gravity explanation show a device like this somewhat  and the are two powers applied.   The spindle has high dc pulses and the sphere wires another    together they will allow a third field to develop between the supplied powers.    We just did not know how to initialize this device      Bashar just did not know and/or give this data.    I hope your device is safe and your able to work on it again.
https://www.youtube.com/watch?v=CsagEYfxPgs
wow   you just may have a real chance at being first at OU with your fine efforts.
NickZ
     Guys:
     Here (below) is Bashar's more recent discussion on spacecraft engine design, given about a month ago.  333.000 hertz,  a special frequency?
     https://www.youtube.com/watch?v=GmrGZJXGyk8
   Could there be a connection between the way these spacecrafts are built, resonating at 333khz, and our solid state Kapanadze/Akula/Ruslan type free energy devices?
   Yes?  No?   Maybe?
                                     NickZ
Hope
Stan Deyo's discussion on antigravity show a device much like this one and how to power it up.   We just did not know enough to finish WTF.
that new Bashar video doesnt seem to help with the details we needed  but the link above does.
