Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
0 Members and 23 Guests are viewing this topic.
Uniqorn
@WTF
For the diamond drilling, did you keep a continuous flow of cooling water on the drill bit?
This water serves two purposes:
1. Flushes out the bits of crystal that would other wise clog up the drill
2. Keeps it COOL - if it gets too hot, it will melt the solder (or glue?) holding the diamond to the bit, thus it will fall off, rendering the drill useless.
High drill speed, gentle steady pressure on the drill, take your time, pulling it out from time-to-time to clear it.
Uniqorn
Some general observations:
1. The device is high-voltage accumulator, as described by Bashar.
2. The device is comprised of conductive and insulating elements.
3. Conductivity and insulating properties are well understood - they combine to make up circuits.
4. We should employ, rather than ignore or abandon, our knowledge about circuits in the usual logical ways that work correctly.
In other words, combine our existing knowledge of electrical circuits with Bashar's plan - then play and experiment.
WTF
I always use water when diamond drilling, and not all diamond drill bits are meant to be high speed every bit is different, depends on manufacture.
When I search for Fibonacci spiral they are all perfect like mine, your forgetting nature isn't perfect, it can't be as it grows, just like people don't look perfect, they have imperfections.
When Bashar said like simulating a sunflower, that was just an example, he had to compare it with something that everyone understands, like Bashar says the Fibonacci spiral is everywhere in nature, but he is just telling you that it is a significant pattern, nothing more. But I suspect if the spirals were not really a proper Fibonacci spiral it still would work to some extent.
If you can do better then make one yourself, after all the more people make them the more chance it has to work.
Uniqorn
Quote from: WTF on January 23, 2014, 03:50:46 AM
Quote"I always use water when diamond drilling, and not all diamond drill bits are meant to be high speed every bit is different, depends on manufacture."
Ok, this means it may have been a faulty drill bit. Anyhow, it tells me you know what you are doing here, after all, you have succeeded in drilling the other holes...
Quote"When I search for Fibonacci spiral they are all perfect like mine, your forgetting nature isn't perfect, it can't be as it grows, just like people don't look perfect, they have imperfections."
What internet are you using - one from some freaky mathless parallel universe? I challenge you to provide me with a link that shows all Fibonacci spirals to be symmetrical, rather than asymmetrical.
Have you studied the Fibonacci spiral, formulas etc? Sunflowers are near perfect Fibonacci spirals, just as 'perfect' as yours, in that anything that is made or grown will have some imperfections. The devices whole purpose is to utilize a Fibonacci spiral - to ignore this is to ignore the core principal of the device!
I just don't understand why you are so hell bent on implementing half of a plan, why you won't listen to what Bashar instructs, when you have stated twice now that you will only take Bashar's word.
If you deviate from Bashar's instructions, then you won't be able to prove him wrong, or right, because it won't be the same device. Apples and Oranges...
Quote"If you can do better then make one yourself, after all the more people make them the more chance it has to work."
This is a fair comment - you seem to be getting a bit fed up with my nagging. ;-)  Indeed, those doing it have a better right to call the shots.
Give me some time. By the way, I will use your method of two bowls. Wish me luck! :-)
WTF
Just type Fibonacci spiral into google and you will see, it can only be made one way with the golden ratio numbers, but anyway good luck and maybe we can compare both of ours.
