question on applying. (a device that might be applicable but not sure on this.)
Started by The Architect, December 03, 2013, 03:00:29 AM
The Architect
would a battery that does not need charging, and draws the power it produces from ambient atomic vibrations from normal or lower than room temperature?  basically any temp above absolute zero would allow it to continue produce the current it produces and would do so indefinitely with only being dropped hard with out protection causing it to break, being able to stop the production of flowing electrons in a DC manner. If so I will post as soon as I have one made that works to meet the specifications of one watt at least.
The Architect
so I am guessing that since no-one has answered even with over 100 views (other than my own single view here to add this reply) that no-one has any sort of an answer or even knows enough to ask for more info to figure out what said answer would be? just a bunch of lookie loos that came in hoping to find tech freely given away. but bringing nothing of value of your own I see. to bad too. Maybe I should work outside of here with it and make sure to put my name all over it so no one comes here and claims its theirs in order to rip off the community here over the prize money. seriously.
by the way should  win this prize money I would expect it to be used to help out some of these people in the world that are going with out even so much as clean drinking water. plain and simple.
Groundloop
The Architect,
First go here: http://www.overunity.com/5707/overunity-prize-conditions-for-1-watt-device-pdf-file-attached/
and read about the terms of how to win the prize.
One of the terms is that it must be open source. One other term is two working prototypes.
This means:
You need to build your prototypes, post all information on this forum, send one prototype to forum owner.
So if you expect people to post any comments on your devices, then they will probably do so after
you have posted information about your project.
GL.
Newton II
Quote from: The Architect on December 03, 2013, 03:00:29 AM
I think your description is not sufficient enough for anybody to think about it.
1)  What about electrodes?  Does anode dissolves or deteriorates after some times?  In that case it cannot be considered a OU device
      because to get back the anode you have to supply equal amount of energy.
2)  Ambient (atmosphere) consists of molecules but not atoms.  Matter in liquid and gaseous state exists as molecules and cannot exist
     as individual atoms. For eg: O2, H2, N2. (may exist as atoms only under special conditions created in a laboratory).   Only solid matter
     may exist as atoms. For eg : Fe, Cu, Al.       I didnot understand the term 'ambient atomic vibrations'.
3)  As per description, a battery is a device which converts chemical energy into electrical energy.  If you are making use of 'ambient
     atomic vibrations'  can you still call it a battery?
truesearch
@Architect:
I would echo what Newton-II pointed out: in order to get more feed-back you need to share more of your idea  :)
There are many knowledgeable and helpful people on this board that might make an observation that you missed. However, some of the users here are less than helpful and simply must be ignored. . . .  :(
Good luck!
truesearch
