How to use our free energy
Started by Cadman, January 29, 2014, 01:53:01 PM
Cadman
As far as I can tell this issue has not been addressed on this forum. My apologies if it has been.
The issue? What to do with the relatively high frequency output from our devices, how best to use it to power our homes during power outages and other times?
I have given this a lot of thought and it seems the options are limited.
As a target I chose 120vac 3500 watts continuous, 5000 watts peak.
The problem to solve:
Given a sufficiently large a bank of 400 volt 60uf caps pulse charged to 300 volts what would be the best way to convert this to 120 vac 50-60 Hz mains voltage? The more economical the better.
Possible solutions:
1. Use the caps energy to keep battery banks charged for use with an inverter, and swap batteries as needed.
2. Use these caps to power a bank of 10 350w-500w peak MSW inverters.
        Could these inverters be paralleled for double or triple wattage?
3. Drive an electric motor coupled to a generator head.
So far I am leaning toward option 2 because an inverter of this size can be made somewhat easily with a couple of transistors, a handful of resistors, a smoothing cap and a rewired microwave oven transformer.
I welcome any comments, ideas or suggestions.
Regards,
Cadman
forest
Either Don Smith style : store in cap then use inverter converting directly from caps to AC quasi or pure sinus or modulate to 50Hz in device and filter via LC filter.
Cadman
Hi forest,
I appreciate your comment.
Don Smith style, eh? More reading for me... :)
Seriously, when you say 'store in cap then use inverter' do you mean switch out the charged cap and use inverter, or run the inverter while the cap is still being pulse charged?
As for 'modulate to 50Hz in device and filter via LC filter' I'm afraid you lost me there, I'm an industrial design engineer, not EE. As this is a lot of watts to handle could you offer any insight as to how this modulation and filtering could be designed? Do you mean the LC inductor would be a transformer primary?
Sorry for all the questions but this is a serious issue for me, it's not idle speculation. I really need to learn a good way to provide smooth power to the inverter(s), preferably while the caps are still being pulse charged. By smooth I mean 48VDC without fluctuating outside of 40-60VDC.
If anyone else would like to join in, I'm all ears.
forest
Sorry, I only said theoretically .... I know that newest inverters are build with ferrite core transformers and a storage caps in the middle : first they chop DC from battery into high frequency, store in 400V cap and then create square, quasi-sine  or sine wave output 230VC AC. That last part is what is needed to get AC from cap. This is Don Smith style because he presented something like that in one of his lecture , storing energy in large 8kV oil caps, he also (in his pdf book) included schematic of  simplified multivibrator to produce output - not complete schematic but an idea...
Second way I believe is used by Tariel Kapanadze, Sr913 and others, but I don't know how it works.
LibreEnergia
My advice would be to disconnect the device and use whatever power supply it used  directly. Far simpler and the efficiency will be higher.
Following that invest the money saved in buying a proper integrating power analyser and use it to measure the output of your device and realise you have been fooling yourself.
