GEM = God's Electricity Multiplier
Started by that_prophet, February 06, 2014, 09:19:10 PM
vineet_kiran
@Artoj
Thanks for the analysis  and sorry for wasting your time.
Reagrds,
Vineet.K.
Newton II
Why don't you use a normal belt and paste a very thick layer of sponge on it  so that power is not lost due to tensioning?
that_prophet
FREE ENERGY HAS BEEN FOUND
http://free-energy.yolasite.com/
   Yes, that is correct, Free Energy has been discovered, this electricity multiplier mechanism is dirt simple, and extremely easy to build, with spare parts even. Building this type of free energy device is not only easy, but is simple also, costing practically nothing to produce. This is mainly because you are able to build this contraption with spare parts, and very few parts at that.
   This device is extremely easy to build, with only a few moving parts, such as at least two pulleys, one large pulley, one or many small pulleys, and a belt, strap, rope or even string in a pinch, to connect the two pulleys together. There are only two more moving parts here, a DC drive motor, and at least one AC output motor/generator. I say at least one, as you could have many more, as the more generators you have, the greater the multiplication factor of your electricity multiplier unit. You can also increase your multiplication factor by increasing the circumference of your drive pulley, or decreasing the circumference of the output pulleys.
   The workings of this miraculous mechanism are pretty straightforward, and can be described by using a multiplication factor of rotations, by merely changing the size of pulleys. You put an extremely small amount of DC electricity into the drive motor, which has a 100cm circumference and only needs to do one single revolution. This drive pulley is connected to at least one one-centimetre circumference mini-pulley that acts as an output device, giving us 100 units of AC electricity, per every output pulley that is connected.
   I suppose that you might be able to see how this could start adding up, giving you 100 units of AC electricity for every output mini-pulley that you attach to the system. If you only added 10 of these mini-pulleys, then you would gain 1000 units of AC electricity, for every single input revolution of the DC motor that you put into this free energy device, otherwise known as GEM = Geometric Electricity Multiplier
that_prophet
·   THIS DOES WORK !!!
It just takes you to look past the lie,
That evil forces are whispering in your ear,
It is pure logic, that pulleys multiply rotations,
+ with AC electricity, revolutions equal AC power,
Satan hides this super simple free energy technology,
By immediately bringing up torque needed to rotate pulley,
Letting you forget AC motors are a breeze to rotate,
You could easily have 10 – 100 of them rotating at once,
And when the drag of load attacks, it is minimized by 1/10th to 1/100th,
Because of it getting divided up, so it lessens it so severely, that it works
Please believe me, and my Lord + Savior, Jesus Christ,,,
God So Much Wants to Give us this Little Miracle Device,
+ He only ask for your faith,,,
SkyWatcher123
Hi folks, Hi that prophet, well there is evidence to support what that prophet is saying.
Imagine an electric machine having no electrical input itself and which, when started on no load by a drive motor and brought up to speed (3250 rpm), thereafter runs steadily at that speed with the motor drawing a little extra input power with a time delay rate of about two minutes. The machine rotor has a mass of 800 gm and at that speed its kinetic energy together with that of the drive motor is no more than 15 joules, contrasting with the excess energy of 300 joules needed to satisfy the anomalous power surge [to spin up from rest]. Imagine further that when the motor, after running five minutes or more, is switched off and the machine is stopped, you can restart it in the same or opposite direction and find that it now has a memory in the sense that it will not now ask for that 300 joules of excess input. 30 joules will suffice provided that the time lapse between starting and restarting is no more than a minute or so. This is not a transient heating phenomenon. At all times the bearing housings feel cool and any heating in the drive motor would imply an increase of resistance and a build-up of power to a higher steady state condition. The experimental evidence is that there is something spinning of an ethereal nature coextensive with the machine rotor. That 'something' has an effective mass density 20 times that of the rotor, but it is something that can spin independently and take several minutes to decay, whereas the motor comes to rest in a few seconds. Two machines of different rotor size and composition reveal the phenomenon and tests indicate variations with time of day and compass orientation of the spin axis. One machine, the one incorporating weaker magnets, showed evidence of gaining strength magnetically, as the test were repeated over several days. I will soon be reporting in detail on these findings, after further work and evaluation of the implications. The phenomenon was something I should have been prepared for, having regard to my years of theorizing, but this discovery was unexpected as it has crept in loud and clear in a project aimed at testing a motor principle totally unrelated to 'vacuum spin'. It has appeared obtrusively and I do not yet know whether, in adapting to its presence, it can serve in improving machine performance or become detrimental."
peace love light
