Tinselkoala's Charrier experiments.
Started by synchro1, February 12, 2014, 02:40:37 PM
synchro1
I came across this video of Tinselkoala's Charrier effect simply with permanent magnets, by Ottavio Pergolizzi; With no electrical coil pulse. What's the permanent magnet motive force driving this horizontal torsion geomagnetic pendulum oscillation, that requires circuital amperian currents in TK's version?
http://www.youtube.com/watch?v=ehUg9emjpqM
1. The Charrier "effect" is not mine (if it exists at all) .... it is Dimitri Charrier's claim to have demonstrated a microNewton scale thrust from an electromagnetic thruster. However he does not measure thrust directly, but rather infers it from tiny measured displacements of his pendulum test article.
2. What I've been doing in my investigation of Charrier's claims is to examine his experimental setup to see if such tiny thrusts can be detected in the first place, over and above all the noise from environmental sources.
3. As can be seen from watching my videos, when the test article is stimulated with current delivered according to Charrier's claims in the paper, there are very strong interactions with the surrounding magnetic environment, nearby metals and probably the Earth's magnetic field.
4. A friend of mine is carrying on a personal communication with Charrier in an attempt to clear up some of the ambiguities in Charrier's original report. For example, Charrier doesn't report actual waveforms of the stimulation applied to his coil, and the parameters he does cite are problematic. We still do not know the exact voltages and currents Charrier used. Certainly when I stimulate my coil with pulses at the slowest frequencies Charrier used, at the voltage level he cites, I see very strong torsional motions that completely override any tiny micro-meter displacements that Charrier measured and from which he inferred the tiny microNewton thrusts.
5. Charrier's work is remarkable for the "cleanness" of his reported data, and for the goodness of fit of his data to his mathematical model. At this point it is incomprehensible to me how he was able to obtain this data. There is something wrong with the levels of current he cites in his 2012 Applied Physics Letters paper.
Charrier explains his paper in a video here, where you can see still photos of his apparatus:
http://www.youtube.com/watch?v=dzggynd5ZoQ
My work so far is contained in four videos, which mostly show the large torsional oscillations that Charrier seems not to have experienced.
http://www.youtube.com/playlist?list=PLml9VdOeqKa_x7_U5azGdKoHsvkCR9eKh&feature=mh_lolz
Now...
6. What does that video from Pergolizzi have to do with my work with the Charrier claims? Nothing, I think. It is unpowered, it is hanging in air, it is hung by a single wire not two.... and it's swinging in torsion, and will continue to swing for quite some time. So? It needs no power input because it is dissipating very little power in the first place. Pendulums like this can effectively couple environmental vibrations into the torsional and vertical pendulum modes and without some damping, can literally continue swinging for longer than you can watch them. So?
ramset
Tinsel
I shared you work here
http://www.energeticforum.com/renewable-energy/16541-viktor-grebbennikov-cavity-structural-effect-2.html#post250608
Doug [the thread Author]will be trying some _Motion Experiments_ based on the alleged "Gravity capacitor".
thanks for sharing your work
Chet
Thanks Grandma
Oh, that'll get them going all right. They love me over there, ever since the Little Miss Mosfet days.
You sure do get me into a lot of trouble, Chet !
(What's Doug doing, pulling wings off flies and beetles or something?)
ramset
I believe Doug will be investigating this
repost below
Grumpy Posted this At OUR [very cool stuff ]
This is the link to the OUR forum
Viktor Grebbennikov: "The flying Russian's" Cavity Structural Effect
Grumpy Quote
""check this out:
http://www.stealthskater.com/Documen...citorArray.pdf
click "view source" here:
Yahoo Groups
first "view source" post references this link:
http://www.amasci.com/caps/capworks.txt
and this link:
WEIRD SCIENCE: The Morton Effect
should be able to figure something out from these
EDIT:
better link
Gravity Capacitor
thx
Chet
ps
I believe your research will be appreciated wherever it is shared.
Thanks Grandma
