mrwayne
Quote from: LibreEnergia on April 13, 2014, 08:40:36 PM
If you claim the energy is some how 'coming from gravity' then show exactly how and where a mass is being lifted that requires less energy input than the potential it gains.
I think you should understand this by now...but if you don't..
You just have to lift cheaper than the output..... Hint "Ratio" input volume and pressure to lift....reduces as you add layers.....
I know - that goes against the belief that hooking systems together only adds input --- but not when the serpentine effect reduces the volume of displacement and increases the pressure faster.....
Catch that "layers of buoyancy" as in the ZED reduce Volume and increase the speed to pressure exponentially....
Which means the ratio of pressure times surface area is spanked
When you can do an up cheaper than the value Down----- the conservative idea needs adjusted..
Just saying.....Super conservative....
mrwayne
Another source might be expansion in the air it contains. This is perhaps more likely.. the amount of verbiage you produce is more than enough to generate the hot air this would require.
No expansion happens in a ZED to lift - we do not pop up like MarkE insisted.
As I have clearly stated so many times - incompressible fluids reduce the need to pa for the expansion losses...
What are the expansion losses - the compression required when raising head inside the ZED?
No. the losses using air are the input volume increase required to reach the proper psi.
Put water and mercury into Mikes spread sheet - and adjust the Load to match.....
SHAZAM!
mrwayne
Quote from: MileHigh on April 13, 2014, 09:00:00 PM
I told you that I might answer the question if you actually posed it so that it was comprehensible.  So who is the real troll I wonder?
This is where you fall flat on your face Wayne.  There is the nonsensical "selective memory" when the discussion is only 20 minutes old.  Likewise, you may be able to razzle-dazze a bunch of retired farmers and their wives out of their retirement savings with your ridiculous nonsensical "Wayne's vocabulary" but not me and not here.
Between the selective memory that only lasts 10 minutes and the nonsensical baby talk it's a wonder that you managed to get this far with your prancing fluids fantasies.
Gee would you repost the question I asked?
mrwayne
Look Everyone,
I only have five days left before I get too busy to answer questions regarding the technology.
I will check in the morning...
p.s. Hey Liberia.. You think well... I have not seen that in a while - no diversion - just straight thinking...
It is fine you do not "believe" our system is possible - if you dig - you will find the answer.
Wayne
MarkE
