Work from 2 magnets > 19% output 2
Started by Floor, February 17, 2014, 01:53:56 PM
Floor
@Lumen
Do you plan to also test the "floor" configuration ?
Would you like me to do a graph set of your last measurments?
@all readers
Please find the attached pdf file    "both pdf".
The motions depicted in this pdf animation are not necessarily
identical to the motions that would actually occur under the conditions
animated.  The lateral displacements of the SLs would tend to occur during most of
the RO rotation, and not only when RO is at maximum repulsion and attraction positions.
                        floor
Floor
The design illustrated in the "both.pdf" is given into the public domain.
It is a method of torque conversion and also a basis for a magnet motor.
                   floor
lumen
Quote from: Floor on September 25, 2016, 02:08:44 PM
@Lumen
                        floor
@floor
At this time I am trying to come up with a good design for a test rig where I could hold many different size magnets and perform rotational and distance moves to collect force data on all the points in between.
I believe I understand now why and how the action provides extra energy but additional data may lead to the optimum configuration.
If I build a universal testing device it would be possible to collect data on many different interactions including yours.
As far as graphing the last data set? I probably wouldn't spend additional time on it thinking additional data is more important at this point but thanks anyway.
We'll see what happens in the next test.
Why do I feel "Steorn" has already done all this and knows the result. Didn't they have a machine to do this exact same thing?
Floor
Floor
@ all readers
I have received a communication from an old user here "lost causes 10X"
Although I do not entirely agree with his conclusion, I am publishing  that
communication here because, I find his observations / insights to be valuable.
One of the ideas he has presented, is that SL magnet  motion is actually twice
the RO magnet motion, and hence the apparent, but not actual OU.
I on the other hand, think that under ideal conditions the work done on SL by the weights
would be exactly twice the work done by RO on its weights.  It is this (ideal 2 : 1) part of his
idea that I find agreement with.
Please find his, the attached PNG file "lost causes 10 X"
                            best wishes
                                      floor
