Jerry Bayles Chiral Effect Homopolar "A" Vector Alternator, and Syncho Coil.
Started by synchro1, March 13, 2014, 10:51:46 AM
synchro1
Sailing boats at the undulating water surface are attracted together by the same mechanism.
synchro1
All one needs to do is to stick an electromagnet coil with a ferrite core on the end of a stack of diametrically polarized neo rings, and pulse it at the correct Pi ratio frequency to generate overunity output. A longitudinal wave is projected from the end of the coil, that goes to infinity almost iinstantly along the axis of symmetry. The magnet stack could be any length, it would make no difference. The stack could be wound with a single wire coil and wired in series to a fast switching diode and variable capacitor. A 9 volt battery and 555 timer would be plenty to achieve the resonant frequencies Jerry Bayles uses. The LC tank would simply have to be adjusted to amplify the field oscillations.
The nature of the gravity  wave would instantly lodge within the magnet core and beat like a heat pumping organ.
synchro1
A new thread entitled the "Solid State Synchro Coil" is in the docks. The "Gyres" of William Butler Yeats resemble the expanding and contracting nature of the longitudinal wave:
gravityblock
@synchro1:  The below images are telling the same story.  This is very old technology as you can see by the tablet of shamash.  Notice how all of the images are similar to the picture you posted earlier in this thread (image on the first row). "The old has been made new again".
The tablet of Shamash (image on the right of the second row) accurately depicts a cymatic frequency (left image of the second row) in great detail, which is vibrating at a certain frequency.  This can also be found at coral castle (left image of the third row), which was built by Edward Leedskalnin, who claimed to know how the pyramids were built.  In addition to this, Ioannis Xydous renders a 2D topology of the aether as found in figure 12 below (fourth row of images) and is a near perfect match to the image found in the tablet of Shamash and to the cymatic frequency, which consists of vortex (positron or positive half wave) and an anti-vortex (electron or negative half wave) pairs.  The E/M wave also consists of a pair of oppossing vortices as found in figure 11 below (fifth row of images).  Figure 11 and figure 12 can be seen in Ioannis Xydous latest work, titled "An Alternate Quantum Physics" (AQP).
Ancient Knowledge (video) <----This is a must see video which explains the above information in full details.  At least watch the last 15 minutes if you don't have the time to see the entire movie.
As a side note:  Technical proof that Scalar Waves exist
Gravock
synchro1
@Gravityblock,
Thanks for the sensational hyperlinks. The Äncient Knowledge video´is worth the three and a half hours. Really enjoyed it! I want to thank you for the enlightening quotes of yours I sewed through the thread. We´ve missed your regular commenting lately, it´s great to find out you´re still with us.
