Need your input on this motor generator
Started by magnetman12003, March 25, 2014, 07:53:11 PM
magnetman12003
Hi All,
I need your input on the developed motor generator video I posted on the You Tube.
A hard wire negative ground wire connects both the input and output of this setup and as
I am finding out strange things are happening.  Some power source unknown to me is assisting the
setup to power lamps that need larger power to operate normally.
Replies need my approval before posting on You Tube to keep out trash talk.
Link is below.
https://www.youtube.com/watch?v=Ri32jT5UQ5c
dieter
youtube became a frustrating sucker, from 5 vids i click , 3 simply refuse to play ("this video is not available"), one crashes the browser and one, with a lot of luck , plays. And then the Ads... crash the browser almost every time. youtube sucks, google destroyed it.
so, sorry couldn't watch it.
The "unknown power source" is the fact that almost certainly your setup is spontaneously oscillating, where the spontaneous oscillation was initiated by the spinning rotor magnet.  So the power source is the power supply.
Your anecdotal observations of the brightness of the LED bulbs is just that; anecdotal.  You would have to make a serious measurement with a digital storage oscilloscope with built-in math functions to truly know how much power is going into each LED light bulb.  Since you don't have that equipment, you can't conclude anything from your clip.
Quote from: dieter on March 25, 2014, 11:55:09 PM
The problem is entirely on your end, it seems.
I agree that doodle has hurt YouTube gravely, but it does still work. If you are having troubles like this often, I suggest you start using Linux for your OS, Firefox for your browser, and browser add-ons like FlashBlock and NoScript.
Quote from: MileHigh on March 26, 2014, 12:46:55 AM
As I have been showing, and as Poynt99 has proven, and as Steve Weir has also confirmed, ordinary modern DMMs do a remarkably good job at reading averages of complex oscillating signals. I am consistently getting less than 5 percent error compared to the digital oscilloscope's reading. Twenty dollars spent on a couple of cheap Harbor Freight DMMs can answer a lot of questions. For light intensity readings, a simple lightmeter with great accuracy can be constructed for under 40 dollars using an Arduino and the TSL235A light intensity-to-frequency sensor chip.
One of a continuing series of DMM checks:
http://www.youtube.com/watch?v=1ST0xgf3xsw
The Arduino light intensity meter:
http://www.youtube.com/watch?v=1Kzf7S-pOEM
Unfortunately I calibrated this meter in actual units of irradiance, power per square cm. I suppose I could calibrate it in half-F-stops too ........   ;D ;D
