The 1,3 MV antigravity and anti-inertia experiment
Started by Tesla_2006, August 26, 2006, 11:30:54 PM
Tesla_2006
Hello, I want to show in a general description my high Voltage (HV) experiment for get antigravity and anti-inertia effect
  I build a system isolated and at the vacuum with a bronze sphere inside, that sphere was hanging of a plastic scion, so that his movement was of type pendulum, in the bottom in the equilibrium state of the sphere there is a flexible electrode connected to a high DC voltage generator for charge it
The sphere was 60 milimeters of diameter and a weight of 1 Kg, the DC generator was a high voltage output up to 1,5 Megavolts
I put the system in way the pendulum movement was in the orientation east-west, I connect the HV generator and the sphere begin in charge, I use a voltimeter adapted for see the voltage in the sphere, meanwhile the voltage go rising there is a movement of the sphere was to the left according to the
conventional Lenz law because there is a current charging the sphere and the current interacting with the Earth magnetic field, all done and normal until that point, but when the voltage exceed the 1,3 Megavolts was a notable change, the sphere moves to the right breaking the Lenz law, the sphere stop his
charge up to 1,5 MV , that is say, there is not current, but the sphere go in "permanent position to the right still adhered to the plastic container", that is say, the force not dissapear, I use many instruments for go in medition of parasit currents, losses, I use DC microammeter, RF detectors and nothing
there is not lectures, then I get a permanent magnet of medium intensity for invert the polarity reference of the Earth magnetic field and I can see the sphere moves to the left with a big force hiting the walls of the container for permanent adherence of the sphere in that walls, again violating the Lenz
law, that is say forces between a static magnetic field and a static charged body, I see this phenomena appears only up to 1,3 MV
When I put away the permanent magnet of the system for leave the sphere again with the Earth magnetic field, the sphere return to the right of the same way than before
But the more interesting of all this was when I take the permanent magnet for invert the Earth magnetic field reference, normally when we move an object of 1Kg of weight by using a permanent magnet, there is a force we feel in our hands for the action and reaction principle of action to distance, but in this case
I don't feel nothing in my hands, not noticeable force was , that is say here too there is a violation of the action and reaction principle, so is as the mass of the sphere was dissapear or not inertial effect
I repeat this test many times and in all the cases the same result and any can go in replication of this special phenomena appears only since the 1,3 MV and I can see a force appears in cuadrature to the magnetic poles of the static magnetic field used in the test
In resume I see when an object is inmersed in a potential diference of 1,3 MV of a static electric field enclose his volume and there is a static magnetic field enclose all the object there is a shift of the gravity vector in the direction in cuadrature to the magnetic poles, that is say the body can fall to the left ,
right, up, down in any direction controlling the poles position and in that condition the intertial mass dissapear of the body
This test can be developed without a high vacuum, I do that for confirmation there is not parasit currents of bad insulation, corona effects, etc,....but remember not exceed the limit of the electric field intensity for the air and not get corona effects
I can do a single conclution about this two fundamental physical laws violation, Lenz law, and action-reaction principle and is for the existence of virtual dipoles in the empty space, when in the space appears this 1,3 MV of potential there is creation of pairs electron-positron generating currents arround the sphere
and a deep variation in the space density and alteration of the gravity sense like a prism and the intertial mass, I do this test based in my references into space energy and some results of some researchers in this theme and there is a single mechanism of single electromagnetism for get antigravity and anti-inertia effects
in a body and so build vehicles of antigravity propieties and get fast variations of movement in 90 dedrees or 180 degrees easy
Bye
hartiberlin
Sounds cool !
Could you please a few pictures or a video of your setup ?
Many thanks.
Regards, Stefan.
Tesla_2006
Thanks, I forget writte that in the before text, I want upload in the next some videos of that experience, but here is more important the replication, some people I know in independant way get the same results and with that general data I show is sufficient
hartiberlin
Okay, looking forward to the videos and picture.
Let them come in.
Many thanks in advance.
Best regards, Stefan.
Megawatt2007
Thanks Tesla for your altruist contribution to this forum and for give for free that 1,3 MV experiment information to all people, I've followed your description and I replicated your tests and the result........... WONDERFULL!!!!!!!!   it works right, for many months I've collected the materials for that testings
Is not needed a video, your explanation says all , only novices can need a video for that full detailed explanation
Applications of this phenomena have wonderfulls contributions for spacial and aeronautics technnology
   Bye.. Bye    :)
