The So-Called Don Smith Generator
Started by Skysabre, April 29, 2014, 03:20:11 AM
Tesluh
I have found it depends heavily on the nst.  To use a new high frequency model, most have gfci that keep it from functioning.  Also found a strange waveform produced by the ones I tested.  had to modify one to get to the center tap to even be able to run the circuit.  I believe that Bertonee was a very important part of the circuit, not made, impossible for me to find.  That's why I am trying the flyback transformer/homemade transformer options.
Tesluh
Would love to hear more about turning cold electricity output into useful hot electricity, if not for 240v 60 hz mains power, than at least for running something like light bulbs or heaters as a stand alone circuit.
How should the end of Don's white board device look to draw from the "8kv battery that never runs down" and use it practically?
Dezeinstein had some great ideas but I'm having a hard time visualizing what he would propose the circuit would look like after Don's 4 large capacitors.
Tesluh
Can you produce cold electricity without doorknob capacitors?  I see many solid state devices built using doorknob caps.
AlienGrey
Quote from: Tesluh on January 02, 2017, 10:49:43 PM
Put it into a rechargeable battery but watch it don't boil the battery fluid or charge caps with it via a UF high voltage diode and EHT caps.
watch you don't kill your self with them.
Tesluh
Can anyone convert Dezeinsteins theory into a schematic?  I am picturing Dons white board device but with voltage divider resistors/supercap banks and an inverter at the end of it.
