COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
web000x
Quote from: SeaMonkey on April 29, 2016, 03:15:50 PM
So the trick then is to achieve an electrical
"pushing back" against the source while at
the same time extracting power to accomplish
some work.
Without some sort of "timing diagram" to
illustrate how this is done it is very difficult to
comprehend.
Is the "taking" and "returning" done at a fairly
high frequency with short pulses over the
complete duration of each cycle of input from
the source?
Or, is it done differently?
"The secret to engineer the dynaflux machine is such that the total reactance, in conjunction with the magnetic field strength, produces a system PF equal in magnitude to the mechanical angle of tilt utilized within the rotor design.  Once this feat has been properly achieved, the generator current will lag the spacial EMF by an angle of 45 degrees, thereby ensuring that the current will reach its maximum value when the rotor's Simple Harmonic Displacement is also a maximum.  This situation then, will foster a condition within  the generator such that the Lenz's force will be a maximum at the very instant at which the driving force reverses.  Thus, the Lenz force and the driving force suddenly become additive, causing an acceleration of the rotor and storage of reactive power in the form of angular momentum.  This stored energy, then becomes the source from which electrical power is derived during the next quarter cycle, and the entire process constitutes a form of resonance when the procedure is optimized."  -  Jim Murray
This is what he said in the Dynaflux Secrets video.  I am going nuts trying to figure out how he achieved this in a transformer with no changing flux paths.
Dave
Meta
Quote from: web000x on April 30, 2016, 03:41:34 PM
Dave
RE: 45 degrees.
Jim Murry's Dynaflux rotor is angled at 45 degrees. Again, he discovers what I already told you previously about 1D=2D or 1=2, 2=4, etc....and about dimensions 1,2,3 and 4.
I wasnt just talking to hear myself.
Remember I said that 90 degrees in our world is 180 degrees in reality? Thats double 90 isnt it.
What is half of 90....wa la!!! 45 degrees....the same angle of the rotor, relative to the shaft, in Jim Murry's machine.
Where talking doubles and halves now.
90 degrees is for our world (3D)
Doubling is for the macro world. 180 degrees (reality, mind, space, 4D)
Halving is for the micro world. 45 degrees (actuality, atomics, 0D=4D)
Whats one half of 45? 22.5 degrees
Whats one half of 22.5? 11.25 degrees
Remember these numbers so you can use them in your machines.
From Dave, " I am going nuts trying to figure out how he achieved this in a transformer with no changing flux paths."
Dave, in your transformer, wind the coils at 45 degrees across the legs and tap the coils on the lowest and highest portions of the coil.
Also try 4 transformers on one axis, each rotated 45 degrees to the former transformer for a spiral total of 45+45+45+45=180 degrees in 4D.
You're catching on slowly, to sacred geometry...some will never listen.
Follow the laws of the universe and the universe will do what you want.
a.king21
Quote from: Meta on April 30, 2016, 09:04:54 PM
RE: 45 degrees.
Is it possible that we could see your device?
Meta
Quote from: a.king21 on April 30, 2016, 10:20:03 PM
My only device is in PDF form, called the MetaQEG. There is no device. I want Dave to build his own transformer device.
Im merely telling Dave how the universe might expect him to wire his transformer to get the results he wants from it.
web000x
I've come to believe in the significance of sacred geometries for the basis of engineering more useful technologies but I have a feeling that the SERPS process can be achieved using standard transformers and generators.  Sacred geometry seems to be more useful in orgone energy devices.
Your theory is vague.  I need direct engineering ideas.  Like utilizing non linear permeability curves in transformer material that facilitates a rapidly changing inductance function that produces the result of negative resistance.  This I can chew on.
Dave
