COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
popolibero
Wow, I see all you guys are very busy replicating the SERPS.... ;)
Mario
listener191
All,
Attached are scope shots showing the composite switching signals overlaid on a 50Hz sine. I provided a composite switching output to make it easier to set up using just a two channel scope.
I am experimenting with two caps which are individually charged in each rising quadrant and individually discharged into each falling quadrant.
At the moment I have the timing circuit set to replicate the timing shown in the SERPS presentation. All pots would benefit being 470K, which would allow complete range coverage without series trimming resistors.
The 4050 buffer shown, is so I can also use my more complicated comparitor based zero cross circuit, which is powered by a +15V rail. This circuit is very accurate and stable over a large voltage range.
The opto based zero cross circuit has been simplified but I had to reduce the input resistors to provide enough current to saturate the opto diodes at 110V 50Hz input. I have run this up to 220V without problem.
I am using two switches initially but I have space on my switching board for 4 isolated bidirectional switches.
Barry
listener191
Should have posted this later circuit which has positive zero cross pulses about 500uS wide.
Farmhand
Quote from: x_name41 on August 02, 2014, 10:48:29 AM
Farmhand calmly I can tell you that you are idiot, my conscience is clear!
I'm happy for you on that. Your opinion of me is irrelevant. You would be better served to take off the rose colored glasses when
assessing other peoples claims. Thane has no OU he never had any OU, his regenerative acceleration is bogus and so is his BiTT.
All reactive power is a portion of the apparent power provided by the power supply. Even if it is used it is paid for. The instant any
reactive power is used it is converted to real power and is consumed.
Think about that.
I can measure several hundred Watts of oscillating - reactive power in a simple setup with only 2 or 3 Watts input, but it's not
real power, my case is to the extreme end of the spectrum, I measure ie. 240 volts RMS and 1.3 Amps RMS with a phase angle
of 40 degrees. so that 240 x 1.3 = 312 Watts, the cosine of 40 degrees is 0.76 which is the power factor.
So 312 x 0.76 = 237 Watts of measured real power, but that power is not actually real power, it's just activity,
If I tap even 1 Watt from the tank (with 2 Watts input) the oscillating power drops to much less. If I tap even close to the same
power out as is input the activity drops to minimal.
Now if I can measure 300 or 400 Watts that does not exist in a setup with less than 2 Watts input from a 12 volt DC supply, then
it is possible to show all kinds of stuff.
Simply put either the SERPS is a case of deception of incorrect measurement or it's the biggest revelation in modern times, you
decide which is the most probable.
All reactive power is a portion of the applied apparent power, and as soon as any reactive power is phase corrected and powers
a load it becomes real power by definition, which is consumed and paid for. So says reality, common sense and logic.
tinman
Quote from: x_name41 on August 01, 2014, 08:15:03 PM
so, you are already two trolls! It was a test which issue you, and how much yet there is such as you?
you deny the obvious, in this way you you are to the detriment on this board because you indicate symptoms of the serious mental health problem, and need to you are being
[/quote)
