COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
I have a circuit up on my bench right now that produces a 5 ns falltime at the load , at a frequency around 270 kHz, using an ordinary IRF830n mosfet driven by a TC4420 driver chip.The driver chip is fed by the output of a Schmitt trigger inverter, and I'm using a 4.7 ohm series gate resistor between the 4420 and the mosfet Gate pin.
web000x
Quote from: TinselKoala on July 05, 2015, 10:47:21 PM
Does the fall time go up the lower the frequency you go?  I am trying to get as close to what Paul said as possible when he very seriously stated that the fall times of his switching need to be 5 ns or less.   What kind of fall time would happen if you had these mosfets running steady state DC and then shut them off?
Thanks,
Dave
MarkE
Quote from: web000x on July 08, 2015, 12:23:11 AM
Thanks,
Dave
Fall time does not have a relation to switching frequency.  It is a function of how fast charge can be driven into the MOSFET gate, and the MOSFET's characteristics: particularly drain to gate capacitance.  Pick an appropriate MOSFET, pair it with a good driver, layout the circuit properly and you can get really fast rise and fall times.
