COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
tinman
Quote from: Meta on April 10, 2016, 09:58:18 AM
From Farmhand on page 9
Here's a strange thing you don't know of and I doubt that Murry and Babcock know of it either.
The Electron Theory of electrons moving from positive to negative, has a diametrically opposite partner called the Hole Theory where electrons move from negative to positive and I make use of it in the MetaQEG device. Electrons move both ways, spiraling around a wire.
Wow-you just discovered true and conventional current flow ;)
Brad
Farmhand
Tinman, is there any chance you could take my name out of that quote ? I have nothing to do with that statement.
Just to make clear the statement in the previous post does not have anything to do with me ! Just sayin.
Khwartz
Quote from: web000x on April 08, 2016, 09:26:11 PM
My circuit is arranged differently now than it was when I made those posts some time ago.
ok :)
QuoteMy caps are arranged on the center tapped leg of the transformer and only allowing the caps to charge in one polarity,
How you do that? You use polarised caps or some diodes? could you make an update schematic please? Dave.
Quotehence the reason the current waveform was 180 degrees out every other half cycle.
. . . Need you schematic, for now, don't follow you :/
QuoteHowever, it seems I've made a measurement error and that last waveform I posted is meaningless.  I've corrected it and my waveforms look more in line with convention now.
. . . Noticed.
QuoteAre you in contact with listener192? Or do you know how to contact him?
Just PM him but I am afraid he will answer you just what he answered to me! ^_^
QuoteThanks,
Dave
Thanks to you to still be interested in this subject if I got some doubts about
citfta
Maybe you should go to one of those schools you despise so much.  You have that theory exactly backwards.  Electrons are negatively charged so they go from negative to positive.  And the holes move in the opposite direction.  Or is it that things in your Meta World work backwards to the real world?
web000x
Quote from: Khwartz on April 15, 2016, 02:55:46 PM
ok :)
. . . Noticed.
This is my generalized schematic:  http://i1082.photobucket.com/albums/j365/web000x/image_zpsq8bci5qx.jpeg
S3 and S4 open when their respective side of the transformer winding goes positive.  When S3 is open, S4 is closed and visa versa.  This allows for the caps to only see one polarity.  You can see in Jim's old SERPS videos that he used polarized caps.  Trying to use unpolarized caps and running the circuit according to my original diagram produces a waveform that is nothing like what paul and jim showed at the conference.  The caps being seated on the center leg of the xfmr and only charging to one polarity is much closer to their waveform.
Dave
