1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
Artoj
Here is an update on the top mechanism. Regards Arto.
gotoluc
Quote from: havuhung on June 04, 2014, 01:44:01 AM
Hi All,
Received from snapshot screen, there is an arc, can be as a steel cable that runs continuously reversal, synchronization with the top of the lever bar. I do not understand, they have contributed to the need for activities this place? . .
At first I also thought there was an arc mechanism of some kind at that location. This is one of the reasons I made the looped video, to better observe it.
I finally concluded it's the same as the other 3 visible upper bars moving in a rotation but it's mostly not visible because the film is overexposed by the light from the window, so it's hiding most of that bars activity but movement is detectable when the bar edges line up with the frame posts and causing a visible arc because it's rotating in a circle.
Luc
havuhung
rc4
Hi all,
It's not a gravity machine, it uses gravity for change torque on axis. Gravity can be changed by anything else. Take 2 objects in rotation 2D (free is better or at least axis more free), if a torque is applied to one object other receive the same in other direction, but like moments of inertia are not the same, each torque don't move same angle. Energy from torque is torque by angle, angle depend of moment of inertia.
gotoluc
Quote from: rc4 on June 04, 2014, 04:32:37 PM
Hi all,
So if gravity doesn't makes the weight turn then it should work in space right?... can you visualize it working because I can't
Luc
