1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
havuhung
Quote from: gotoluc on June 21, 2014, 01:15:20 AM
Update
Spent all day making the elliptical mechanism (part).. still need to fine tune it tomorrow and then I'll give it a test run. Not an easy part to make!   much precision is needed. Parts need to be exact same centers or it jams up.
Luc
Hi gotoluc,
will soon succeed.
netica
Hi everyone,
Don't want to bother you to much this is my first post here. I was interested in this project back on Energetic Forum, but for some reason my account has been banned I get the message -
"Sorry. The administrator has banned your IP address. To contact the administrator click here"
The click here does nothing that allows me to contact them, so I am completely blocked out.
I know that some people use both forums and since I have no way of contacting them will someone be kind enough to ask Aaron Murakami to investigate what has happened to my account.
I can think of no reason that I should have been banned as I have done nothing wrong there.
I find it very frustrating that there is no way of contacting them.
It may be best to use the same topic forum as this one over on Energetic Forum as Aaron is quite active on it at the moment.
Thanks, and sorry to bother you.
Kind Regards
netica
netica
Hi All,
I don't know what was happening but I am able to log in like normal on Energetic Forum now so thanks anyway.
netica
gotoluc
Quote from: havuhung on June 21, 2014, 04:19:28 AM
Hi gotoluc,
will soon succeed.
Not with the mechanism you suggested!... did you know it needs 2 drive gears and going in opposite directions for it to work?... guess I trusted it would adapt to my single gear and didn't realize until 16 hours of building and after I installed it.
Here's the video: https://www.youtube.com/watch?v=-e8jUYrjOAU&feature=youtu.be
I'm going to be taking a break as I've been at this for 13 days straight 12 hours a day.
Luc
Artoj
Hi Luc,
I can see you got into a jam. This design should work (no guarantees) it is a slight modification from my Hyperbolic Drive design, it will produce ellipses and many other interesting permutations from eggs to all form of hypercyclic shapes and patterns, the requirement would be a variable speed on the second sprocket/gear/pulley/directdrive. I have drawn it as a 1/2 speed form, which gives an ellipse, this would be easy to adapt using chains etc. The original Skinner design would be very similar to what I have here. The drawings are quick sketches, just adapt your materials to suite. I hope this helps with your build, regards Arto.
