1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
ARMCORTEX
No, I make this machine that I invented.
More powerful than Skinner, only loss is by purposeful pulse, bearing and pulley loss, motor must simply refill storage system in time.
I will get the synergistic effect of pulse system that you wont, and the little cult will cry.
Drive to speed via one way clutch then release shaft drive and only drive from disconnected middle.
Sorry, I only have time for the best, and I make for real with big investment and big planification, using metal.
ARMCORTEX
No! You are confused.
I make torque arm like this, but better.
http://www.youtube.com/watch?v=ODf49HtCNj0
It doesnt cost much to keep flywheels in motion.
You pay only for push/pulse/loss. And here, ''aspden effect'' will be here, + DePalma effect of rotating pendulum bob.
You will not have Aspden effect or depalma effect.
My invention based on Dimitriev >>> William Skinner 1939 device.  The whole Skinner cult will be defeated with their puny 1.5 HP (1100 watts) output.
Bye!
ARMCORTEX
You pointed out the only non-advantageous force of the mechanism, I was aware of that and have a solution, but this makes it also simple and precise contact point, a good compromise.
There will be a counter force, if the ramp is included into the mobile frame, you are right.
But there will be a net forward force, same principle as him with his feet, In fact, I think he is generating much torque..
https://www.youtube.com/watch?v=eB1ygJh8PEE
https://www.youtube.com/watch?v=ajIQhdDYSEo
https://www.youtube.com/watch?v=N6G5aC9BtSc
My new re-design will allow the heavy wheels to push themselves on immobile external static ramps. Placement must be absolutely perfect for every wheel.
I still think however that pushing from the frame will be just fine, you have to remember that this lower area is lower speed and will have much forward mass and will never be pushed back, its as good as static concrete, just slightly less delta, what matters is the difference relative to.
Deal with it bro.
Kator01
Armcortex,
go ahead.. it works. Found this here however almost any trace in the internet is gone:
http://www.youtube.com/watch?v=MVuIHm6ADQ4&feature=youtu.be
Kator01
Kator01
