* Good video set.
Started by maurilappi, September 19, 2014, 03:44:48 PM
maurilappi
Arto Lauri 106. PINK
https://www.youtube.com/watch?v=-HOhseTNUkY
Arto Lauri 105. Radiaton pressure
https://www.youtube.com/watch?v=3SwP5zl1iVE
The radiation pressure of 30mm OIL
In the latest music videos by 105 Arto showed how DIRECTLY beetanopeitten electrons surge of radiation source caused an exam, a minimum rating of 30mm oil statue of pressure build-up.
Old (1911) in the literature, very few have already been told how the physical photon radiation pressure are able to rotate the infinitely delicate movements of the paddle wheel in a vacuum.
But the essential difference between test systems. Even in those old journals Russian rule does not, however, been possible to make changes measured values ​​numerical form. Amazed hindsight, why not?
30mm height of the oil is not a stunningly large measurement standard. (Air pressure when there is a 10m water).
On the other hand brings paperless vacuum reading is more than a revolutionary FACT!
Arton used by the vacuum pressure, however, was only of the order 5Pa.
That is, 10 000mm / 100 000 = 0.5 mm water column.
So, however, received 30mm of oil pressure indicates a relatively large atomic plasma in a vacuum of a recurring radiation pressure. The pressure must be relative to the solar sail used in proton RADIATION fuel in space. Or even NASA spoken by ION engines spacecraft. Tellingly, that these things pressure values ​​have been reflected in any publications. So Arton test is here too, contributes to class of its own!
Säteilyn paine 30mm ÖLJYÄ
Viimeisimmässä videossaan 105 Arto osoitti SUORAAN miten beetanopeitten elektronien syöksyminen säteilyn lähteestään aiheutti koetilanteessa vähintään luokkaa 30mm öljypatsaspaineen muodostumisen.
Vanhoissa (1911) alan julkaisuissa, ani harvassa on JO aiemmin kerrottu miten fyysisten fotonien säteilyn paineet kykenevät pyörittämään äärettömän herkkäliikkeistä siipiratasta tyhjiössä.
Mutta oleellinen ero koejärjestelyissä. Noissakaan vanhoissa julkaisuissa Venäjän vallan ajoilta ei kuitenkaan oltu kyetty muuttamaan mitta-arvoja numeraaliseen muotoonsa. Hämmästyn näin jälkikäteen miksei?
30mm Öljyn korkeutta ei ole mikään häikäisevän suuri mittanormaali. ( Ilman paine kun on 10m vettä).
Toisaalta aineettomassa tyhjiössä tuokin lukema on enemmän kuin MULLISTAVA FAKTA!
Arton käyttämän tyhjiön paine oli kuitenkin vain luokkaa 5Pa.
Eli 10 000mm/ 100 000= 0,5mm vesipatsasta.
Joten kuitenkin saatu 30mm öljyn painetta kertoo suhteellisen suuresta atomiplasmaan tyhjiössä kertautuvasta säteilyn paineesta. Paine täytyy olla suhteessa aurinkopurjeissa käytettävään PROTONISÄTEILYN polttoaineeseen avaruudessa. Tai vaikka NASA puhumiin IONI moottoreihin avaruusaluksissa. Kuvaavaa, ettei näittenkään PAINEARVOJA ole näkynyt missään julkaisuissa. Joten Arton koe on tältäkin osaltaan aivan omaa luokkaansa!
maurilappi
_________________________________
Arto Lauri 107. Professors,KPA
https://www.youtube.com/watch?v=Sk83vwZCivQ
* Mikhail Gorbachev speaking 01.2015.
fission explosion fission explosion
Mikhail Gorbachev has otherwise become public in Russia unexpectedly. West's most respected by the country's former president, no small fry, therefore!
It was said that mankind's last moments is at hand. Since nuclear power completely unsustainable use is killing THE WORLD !!
Speech was preceded by 01.09.2015 at 16 to 17 on the Finnish side seen a massive red is very strong firmament oxygen periphery of the ionization flash of Russia!
This phenomenon is explained harsh truth. Chelyabinsk nuclear waste storage uncontrolled fire proceeds 1,5 years after the STILL, also in the USA! And chemitrail also does not help to keep the nuclear waste emissions in the world at bay!
* Mihail Gorbatsov puhe 01.2015.
fissio räjähdys fissio räjähdys
Mihail Gorbatsov on muuten tullut julkisuuteen Venäjällä yllättäen. Lännen eniten kunnioittama maan entinen presidentti, ei mikään pikkutekijä siis!
Oli sanonut, että ihmiskunnan VIIMEISET HETKET ON KÄSILLÄ . Koska ydinvoiman täysin kestämätön käyttö on tappamassa KOKO MAAILMAN!!
Puhetta edelsi 09.01.2015 kello 16-17 Suomen puolella nähty massiivinen punainen erittäin voimakkaan taivaankannen happikehän ionisaation välähdys Venäjältä!
Ilmiö kertoi karun totuuden. Tsheljabinskissä ydinjätevarastojen hallitsematon palo etenee 1,5v jälkeen YHÄ, myös USA:ssa! Ja chemitrailaus myös ei enää auta pitämään ydinjätepäästöjä maailmalla aisoissa!
maurilappi
Arto Lauri 108. Clear air
https://www.youtube.com/watch?v=35MNC7x3aGY
FB. M. A. Gustafson 1920 map
occupation occupation occupation
When looking at this insightful M. A. description of the map. So .. How nice it now, I would say. Understands why Russia will start to bring Finland in the spring of 2015 the war troops. Tens of thousands of conqueror already embattled country by the masses. Finland in the Baltic Sea it receives for its 600MW navy / missile / HAARP of weapons at their base miehitysjoukkot quick ride alone.
Each of this intention -ennustus map realizes Russia to Pyhäjoki nuclear 600MW electric ice in Finland is not in any other, as the Sweden-NATO Norway - the attack on the Centre's maintenance energies! Completely naive to imagine more. That the Holy River 100% Russian thousand-headed first-commando should be 10 000V electric fences slaughter of safeguarding our country no other task.
Nordic occupation opens so agreed to Russia DIRECT road the heart of Europe. For the Finnish government NUCLEAR MATERIALS DEALERS now, oval eyes also lust to start World War III that his project just drawn map formulas! Unbelievable how Finland's nuclear industry is in front of their projects ready for anything. In order to maintain a deadly horrific nuclear weapons fabrications. Creative destruction of nuclear weapons for the sale of force if necessary. Even in their native country!
The map is Gustav Johansson in 1920 according to the publication.
http://kuvapilvi.fi/k/yJHq.jpg
[Img] http://kuvapilvi.fi/k/yJHq.jpg [/ img]
FB. M.A. Gustafson 1920 kartta
miehitys miehitys miehitys
Kun katsoo tätä oivaltavaa M.A. kuvauksen karttaa. Niin.. Miten sen nyt kauniisti sanoisin. Ymmärtää kyllä miksi Venäjä alkaa tuoda Suomeen jo keväällä 2015 sotajoukkojaan. Kymmenet tuhannet valloittajana nyt jo sotaa käyvän maansa massat. Itämereen Suomelta sitä varten saamaansa 600MW laivasto/ ohjus /HAARP aseitten tukikohtaansa miehitysjoukkot pika kyydityksin.
Jokainen tästä aie -ennustus kartasta tajuaa, Venäjä tarvitse Pyhäjoki reaktorin 600MW sähköjään Suomessa ei mihinkään muuhun, kuin kyseisen Ruotsi-NATO Norja - hyökkäyskeskuksen ylläpidon energioihin! Täysin lapsellista edes kuvitella muuta. Että Pyhäjoen 100% venäläinen tuhat päinen ensi-iskujoukko tulisi 10 000V sähköteurastusaitojen turvaamana maassamme mitään muuta tehtävää varten.
Pohjolan näin sovittu miehittäminen aukaisee Venäjälle SUORAN tien Euroopan sydämeen. Sillä nämä Suomen hallinnon YDINASEMATERIAALIN MYYJÄT nyt silmät soikeina myös himoavat aloittaa kyseisellä hankkeellaan III- maailmansotansa juuri piirretyn kartan kaavoillaan! Uskomatonta miten Suomen ydinteollisuus on hankkeittensa eteen valmis mihin TAHANSA. Saadakseen vaan ylläpitää tappavan, kauhistuttavan ydinasetehtailunsa. Luovat ydinaseilleen tuhon myynnin markkinat vaikka väkisin. Jopa omaan synnyin maahansa!
Kartta on Gustav Johanssonin 1920 julkaisun mukainen.
maurilappi
Arto Lauri 109. Wor War III
https://www.youtube.com/watch?v=RIn4urM9WHo
Fukushima 1 plant robot was destroyed as soon as the radiation
IL / power plant accident in Fukushima, this looks like inside - a person would not survive an hour to survive
Wednesday, 15.04.2015 at 13.35
Man can not survive destroyed the Fukushima power plant radiation hours to survive. The robotic cameras were sent to the devastated Fukushima nuclear power plant to investigate how there seems to. The robotic cameras were sent to investigate the way in which the melted nuclear fuel can be transported from the power station. Source: CNN
* I just heard a very important additional news topic from Germany tulleelta person. Fukushima robot camera does not reportedly only DESTROYED. Rather, it simply boils at nothing researchers in the eyes !. . .Kuulitte Correctly. the robot had been hit so hard irradiation, it reportedly directly gassed AIR. As Fukushima-1 reactor fuel 100t cargo also found muon measurements in the same area in the past committed!
No surprise, however, these phenomena are no longer those who have seen how the explosive fission reactors within the radiation energies of the form according to the measurements million degrees IMMEDIATELY path CHANGING EVERYTHING gas inferno.
Fukushima 1 laitoksen robotti tuhoutui heti säteilystä
IL/ Tältä Fukushiman turmavoimala näyttää sisältä - ihminen ei selviäisi tuntia hengissä
Keskiviikko 15.4.2015 klo 13.35
Ihminen ei selviäisi Fukushiman tuhoutuneen voimalan säteilyssä tuntia hengissä. Robottikamerat lähetettiin Fukushiman tuhoutuneeseen ydinvoimalaan tutkimaan, miltä siellä näyttää. Robottikamerat lähetettiin tutkimaan myös tapaa, jolla sulanut ydinpolttoaine voidaan kuljettaa pois voimalasta. Lähde: CNN
* Kuulin juuri todella tärkeän lisäuutisen aiheeseen Saksasta tulleelta henkilöltä. Fukushiman robottikamera ei kuulemma pelkästään TUHOUTUNUT. Vaan se yksinkertaisesti KIEHUI olemattomiin tutkijoiden silmien edessä!. . .Kuulitte aivan oikein. robotti oli osunut niin kovaan säteilytykseen, että se kuulemma suoraan KAASUUNTUI ILMAAN. Kuten Fukushima-1 reaktorin 100t polttoainelastin myös todettiin myoni mittauksissa samalla alueella aiemmin tehneen!
Mikään yllätys kuitenkaan tällaiset ilmiöt ei ole enää niille, jotka ovat nähneet miten fissioiden räjähtävien reaktorien sisällä säteilyn energiat muodostavat mittausten mukaan MILJOONAN ASTEEN HETI TIELTÄÄN KAIKEN MUUTTAVAT KAASUKSI INFERNOT.
maurilappi
Arto Lauri 110. The Photon
https://www.youtube.com/watch?v=Nwj4dni_hic
Henri Lentonen/ Tomi Tee Tuomala haastattelu
https://soundcloud.com/tomi-tee-1/as...ja-haastattelu
Electron Volt = temperature in Kelvin
wow wow wow wow wow wow
The electron volt, and text temperature Wiki.
A certain areas of physics, such as plasma physics, it is practical to use mass to a temperature in electron volts
determined using Bolzmann constant kB:
1eV 1,60217653(14) X 10^-19J
_____= _________________________ = 11 604,505(20) K
kB 1,3806505(24) X 10^-23J/K
For example, a typical magnetic fusion plasma is limited 15kV or 175 million degrees Kelvin.
The numbers in parentheses are the measured value of the last two digits the standard deviation.
Ekvipartitio theorem of classical thermal equilibrium thermodynamic system the average energy per degree of freedom is ½kT, where T is the temperature. The ideal gas particles have three degrees of freedom, so the ideal gas energy per particle an average of 3 / 2kT.
That's Mark's last formula is a professional expert quite TOP! According to that should now be able to directly determine the 200MeV explosive single uranium atom temperature in the reactor directly. The nuclear bomb is defined directly in the millions of degrees! There is thus a nuclear reactor STUK lies + 300C at all!
This is ever so important piece of information Marco. As evidence directly previous argument that a nuclear reactor uranium fuel is always based on the fumed pressurized air directly PLASMA GAS IN! Can Marco shows the relevant data more formula? Russian data on the other hand says uranium pellet temperature is always more than the uranium boiling + 4131C. The class + 5000C. So the fork temperatures IS. But ALWAYS uranium occurs CHANNEL RADIUS gas!
* Self calculator uranium pellets in the internal temperature of the power; / cm3 according to. Metal halide lamp 4 200K with the formation of 100W / cm 3 according to.
And when the uranium in the capsule while it is 148W / cm 3. Produce the temperature here
148W / cm 3 / 100W / cm3 4200K = X + 6 216k uranium pellets rattling temperature. That is more than six 000C
Marco
"If the capsule is formed around the uranium Tsherenkov general type of plasma, is a capsule where the water collects in vacuo, and the gases ..."
* Yes, there is, so that when the plasma radiation, the pressure is formed, so that the gas pressure due around there is so little air molecules / cm 3. That technically it is a vacuum! Well noticed brings ..
Elektronivoltti= lämpötila kelvineinä
woW Wow Wow woW Wow woW
Elektronivoltti ja lämpötila Wikitekstistä
Tietyllä fysiikan alueilla, esimerkiksi plasmafysiikassa on käytännöllistä käyttää elektronivolttia massan lämpötilaan
määritellään käyttäen BOLZMANNIN vakiota kB:
Esimerkiksi tyypillinen magneettisesti rajoitetun fuusion plasma on 15kV tai 175 miljoonaa kelviniä.
Suluissa olevat numerot ovat mitatun arvon kahden viimeisen numeron keskihajonta.
Klassisen ekvipartitio teoreeman mukaan termisessä tasapainossa olevan termodynaamisen järjestelmän keskimääräinen energia vapausastetta kohti on ½kT, missä T on lämpötila. Ideaalikaasun hiukkasilla on kolme vapausastetta, joten ideaalikaasun keskimääräinen energia hiukkasta kohti on 3/2kT.
Tuo Marcon viimeinenkin kaava on ammattiosaajan ihan HUIPPUA! Tuon mukaan pitäisi nyt kyetä suoraan määrittelemään 200MeV räjähtävän yksittäisen uraaniatomin LÄMPÖTILAT reaktorissa suoraan. Ydinpommissa se määritellään suoraan olevan MILJOONISSA ASTEISSA! Ei siis ydinreaktorin STUK- valheiden +300C alkuunkaan!
Tämä on HURJAN tärkeä tieto Marcolta. Koska todistaa SUORAAN aiemman väitteen, että ydinreaktorissa uraanin poltto perustuu AINA ilmaan suoraan höyrystetyissä paineistetuissa PLASMAKAASUISSA! Osaako Marco esittää asiaan lisää kaavadataa? Venäläinen data toisaalta sanoo uraanipelletin lämpötilan olevan aina yli uraanin kiehumisen +4131C. Luokkaa + 5000C. Joten haarukkaa lämpötiloissa ON. Mutta AINA uraani esiintyy KANAVASÄDE KAASUNA!
* Itse laskin uraanipelletin sisäisen lämpötilan tehona/cm3 mukaan.
Metallihalidi lampun +4 200K kun muodostuu 100W/cm3 mukaan.
Ja kun uraani kapselissa se taas on 148W/cm3. Saadaan lämpötila tästä:
148W/cm3/ 100W/ cm3 X 4200K= + 6 216K on uraanipelletin hurja lämpötila. Eli yli +6 000C
Marco
"Jos uraanin kapselin ympärille muodostuu ylipäätään Tsherenkov tyyppistä plasma, on kapseli silloin tyhjiössä ja vesi kerää kaasut..."
* On kyllä niin, että KUN plasmaa säteilyn vastapaineesta muodostuu, niin tämän kaasun paineen takia ympärillä ON niin vähän ilmamolekyylejä/ cm3. Että teknisesti kyse ON tyhjiöstä! Hyvin huomattu tuokin..
