* Good video set.
Started by maurilappi, September 19, 2014, 03:44:48 PM
maurilappi
_________________________________
Arto Laur 111. Bolzmann constant
https://www.youtube.com/watch?v=uJwiXRIkImA
Arto Lauri 110. The Photon
https://www.youtube.com/watch?v=Nwj4dni_hic
Plasma VACUUM
what what what
> > "If the uranium is formed around the capsule type plasma Tsherenkov in general, is a capsule where the water collects in vacuo, and the gases ...">
> * It is indeed so that when the plasma radiation, the pressure is formed, so that the gas pressure because there are so few around (EE Lähteenkorva specified by the vital intermediary electron-containing air molecules / cm 3.) So technically it is a vacuum! Well noticed brings ..
> This is what interests me, therefore, that the plasma has the vacuum features!
> Terv: J
* Had the CIA / SUPO teeth and illegally made redundant within 2h. Because his works dealt with chemitrail projects related to the secret, for example, Vaisala available climate reports. Guy seems to be held secret data, such as the most recent Bolzmann- videostani you notice.
That radiation pressure generated by the vacuum is otherwise LARGE encrypted mystery. I thought myself that the world's hottest point could be found in black hole. When I was looking out the background for my video. But what yet! While opening a vacuum cleaner material at point than which. The black hole's temperature is the most complete VACUUM what is known! ..
Temperature ABSOLUTE VACUUM!
This is only possible when opening flung radiation pressure. Hawk virtual radiation from the drive ALL transmit energy electrons off. This finding is in my view, stunning. You know, I always wondered why the glowing hot uranium capsules under water TVO Rh-eye appears to be in the hall. Not supposed white-hot, but unbelievably super black! The only inside the energy out of feeding the visible phenomenon is TSHERENKOVIN veil flocking to convey the energy of electrons.
http://kuvapilvi.fi/k/yHga.jpg
[Img] http://kuvapilvi.fi/k/yHga.jpg [/ img]
Plasman TYHJIÖ
mikä mikä mikä
> > "Jos uraanin kapselin ympärille muodostuu ylipäätään Tsherenkov tyyppistä plasma, on kapseli silloin tyhjiössä ja vesi kerää kaasut...">
> * On kyllä niin, että KUN plasmaa säteilyn vastapaineesta muodostuu, niin tämän kaasun paineen takia ympärillä ON niin vähän (E.E. Lähteenkorvan mainitsemia elintärkeitä, välittäjä elektroneja sisältäviä ilmamolekyylejä/ cm3.) Että teknisesti kyse ON tyhjiöstä! Hyvin huomattu tuokin..
> Tämä minua kiinnostaisi siis että Plasmalla on Tyhjiön ominaisuudet!
> terv: J
* Joutui CIA/ SUPO hampaisiin ja laittomasti irtisanotuksi 2h sisällä. Koska töissään käsitteli chemitrail hankkeisiin liittyviä salaisia esimerkiksi Vaisalassa saatavia ilmaston raportteja. Kaverilla näyttää olevan hallussa salaista dataa, kuten uusimmasta Bolzmann- videostani huomaat.
Tuo säteilypaineen synnyttämä tyhjiö on muuten SUURI salattu mysteeri. Luulin itsekin, että maailman kuumin piste löytyisi Mustasta aukosta. Kun etsin asian taustaa videotani varten. Mutta mitä vielä! Vaikka aukko imuroi ainetta pisteeseensä kuin mikäkin. Mustan aukon lämpötila on täydellisin TYHJIÖ mitä tunnetaan!..
Lämpötila ABSOLUUTTINEN TYHJIÖ!
Tämä on mahdollista VAIN kun aukosta sinkoavat säteilyn paineet. Hawkinin virtuaalisäteilystä lähtien ajaa KAIKKI energiaa välittävät elektronit pois. Havainto on mielestäni mykistävä. Tiedätkö, olen AINA ihmetellyt, miksi hehkuvan kuumat uraani kapselit veden alla TVO Rh-hallissa silmiin näyttäytyy. Ei oletetun valkohehkuisina, vaan käsittämättömän super mustina! Ainoa sisältä energiaa ulos syöttävä näkyvä ilmiö on TSHERENKOVIN hunnun parveilevat energiaa välittävät elektronit.
maurilappi
Arto Lauri 112. Gene Simmons, birds
https://www.youtube.com/watch?v=FyPr7mXVhZg
Arto Lauri 111. Bolzmann constant
J. "Realistic HYDROGEN ION"
FREE ENERGY device
April 23rd, 2015
This below-mentioned patent texts and formulas may be of interest to you, too, the inventor has already been murdered, perhaps he came up with something that liked to hide, such as under-mass hydrogen, and the plasma it formed.
WO2002031833.
Espacenet the same:
http://worldwide.espacenet.com/publicationDetails/originalDocument?CC=WO&NR=0231833A1&KC=A1&FT=D&ND=3&date=20020418&DB=EPODOC&locale=fi_FI
¤http://worldwide.espacenet.com/publicationDetails/originalDocument?CC=WO&NR=0231833A1&KC=A1&FT=D&ND=3&date=20020418&DB=EPODOC&locale=fi_FI
Even in these stories is wild stern, Randell Mills speaks more ie below-mass of hydrogen and other interesting of topics:
http://www.blacklightpower.com/publications/
J. "Realistinen VETYIONI"
VAPAAENERGIA laitteesta
23.huhtikuuta 2015
Tämän alla mainitun patentin tekstit ja laskukaavat saattaa sinuakin kiinnostaa, keksijä on jo murhattu, ehkäpä hän keksi jotakin mikä piti salata, kuten esimerkiksi ali massainen vety, ja siitä muodostuva plasma.
WO2002031833.
espacenetin kautta sama:
Näissäkin jutuissa on vinha perä, Randell Mills puhuu lisää alimassaisesta vedystä ja muista kiintoisista aiheista:
maurilappi
Arto Lauri 113. BESSERWISSER
https://www.youtube.com/watch?v=NXdE8IBT8Jw
3430. Appendix Table Odds
Even Albert Einstein said directly that energy can be lost. It can mainly spread into the environment. But when STUK / IAEA speak protection against radiation between the radiation source mounted on construction. Who would be able to prevent the radiation coming through. Are being systematically overlooking the agreed global level conspiracies!
In a world where there is no known substance that would be able to capture the energy of radiation to prevent sticking! Even argument absorption is silly! Nevertheless, decade after decade saw STUK and the IAEA will provide to teach in universities and colleges!
No justification, let alone answer, however, is not provided. Not even if I was seeing TVO's practical field work. How do I placed on top of radiation fountains thick lead shields, even water began just a few weeks of radiation inside a thief actions to radiate even more. Like the original source of radiation! Witch radiation intoxicated yellow pencil shelters.
TVO then decontamination of enclosed spaces. "Cooling" less radiating to the end of the period after the revision. It took me many years to find this phenomenon encrypted encrypted at all for some written confirmation. How to be the only source of our country is self-STUK published! Which proves that a systematic cover-up relating to Appendix I told the table in the nuclear field is a calculated.
Even based on the table, STUK asked to agree in any way to comment on. All the same, this photocopy is now fuming topic gun. The entire global model of radiation protection against the principles of the World reactors slump.
3430. Lisäyskerrointaulukko
Jo Albert Einstein suoraan sanoi, ettei energia voi kadota. Se voi lähinnä vain levitä ympäristöön. Mutta kun STUK/ IAEA puhuvat säteilyä vastaan suojautumisista säteilyn lähteen väliin asennettavilla rakenteilla. Jotka kykenisivät estämään säteilyn tulemisen lävitse. Ollaan systemaattisesti globaalissa tasossa sovitun salaliittojen äärellä!
Maailmassa kun EI tunneta mitään sellaista ainetta, joka kykenisi ikuista säteilyn energian läpi tunkemista estämään! Jo väitteenä absorptio on huuhaata! Siitä huolimatta vuosikymmenestä toiseen näin STUK ja IAEA antavat opettaa yliopistoissa ja korkeakouluissa!
Mitään perustetta saati vastausta kuitenkaan ei anneta. Ei vaikka itse olin näkemässä TVO:n käytännön kenttätyössä. Miten säteilyn lähteitten päälle laitetut paksut lyijysuojat, jopa vesi alkoivat muutamissa viikoissa säteilyt sisäänsä varastoimina säteilemään jopa enemmän. Kuin alkuperäinen säteilyn lähde! Noita säteilystä myrkyttyneitä keltaisia lyijysuojia.
TVO:lla sitten DEKONTAMINAATION suljetuissa tiloissa. "Jäähdytettiin" vähemmän säteileviksi loppu vuodet revision jälkeen. Minulta meni vuosikaudet löytää tälle salattuakin salatummalle ilmiölle ylipäätään jostain kirjallista vahvistusta. Kuinka ollakaan Maamme ainoa lähde on itsensä STUK:n julkaisema! Mikä todistaa, että Lisäyskerroin taulukkoihin liittyvä systemaattinen salailu on ydinalalla laskelmoitua.
Edes taulukkojensa perusteita STUK kysyttäessä suostu millään tavoin kommentoimaan. Yhtä kaikki tässä valokopioni on nyt aiheeseen  savuava ase. Koko globaali malli säteilyn suojautumisen periaatteista Maailman reaktoreilla romuttuu. Jo tällä yhdellä valokopiolla kyseisestä kirjasta:
http://kuvapilvi.fi/k/yHc3.jpg
maurilappi
SEE IT
__________
Much has been folded types of it. Can radiation deadly force to get visually visibly attire.
As always, it is in one of the party was quite straightforward ways to get escape from these reactors tons of uranium visual leak fugitives physically visible form.
And as the initialization already gave to expect. Again, becoming something like that. That makes viewers more than convinced that this is more than a documented chilling truth. .. ...
Arto Lauri 114. Argon
[link to www.youtube.com (secure)]
Arto Lauri 114.B Milk
NÄE SE
__________
Paljon on taitettu peistä siitä. Voidaanko säteilyn tappavaa voimaa saada visuaalisesti silmin nähtävään asuun.
Kuten aina, on eräällä henkilöllä ollut varsin suorasukaisia tapoja saada nämä uraanista karkaavat visuaaliset reaktoreista tonneittain vuotavat karkulaiset
fyysisesti näkyvään muotoon.
Ja kuten alustus antoi jo odottaa. Jälleen tulossa jotain sellaista. Joka saa katsojat enemmän kuin vakuuttuneeksi siitä, että tämä on enemmän kuin dokumentoitavissa oleva kylmäävä totuus . .. ...
maurilappi
Arto Lauri 115. Plasmon
https://www.youtube.com/watch?v=k2AurgTfQjU
Arto Lauri materiaali koosteet
http://www.suomenetu.com/33
https://www.youtube.com/watch?v=L_4Q6dB_SiM
YLE Text TV 05.19.2015
"STUK. Radioactive niobium-95 and cobalt-60 emission of the substance have been found in Kotka without radioactivity monitoring position a week ago the collected samples. Until assembled Sodankylä samples."
* Joopa JOO. A week ago, started in Finland specifically TVO revisions, not Loviisa. And Sata Milk collection areas within a radius of 100 km TVO. It is precisely those STUK's a sampling of the Regions BETWEEN. MOT!
Arto Lauri 114. Milk Yotube in real time on the video told ONCE AGAIN!
YLE teksti TV 19.05.2015
"STUK. Radioaktiivista niobium-95 ja koboltti-60 päästön ainetta on löydetty Kotkan ilman radioaktiivisuutta valvovasta asemasta jo viikko sitten kerätyistä näytteistä. Aina Sodankylästä koottuihin näytteisiin asti."
*Joopa JOO. Viikko sitten alkoi Suomessa nimenomaan TVO revisiot, ei Loviisan. Ja Satamaidon keräilyalueet on 100km säteellä TVO:sta. Juuri noiden STUK:n näytteenottoalueiden VÄLISTÄ. MOT!
Arto Lauri 114. Milk Yotube video kertoikin asiasta reaaliaikaisesti JÄLLEEN KERRAN!
