Magdrive HHO Generators
Started by ZeR888, September 12, 2006, 05:42:34 PM
Moab
Why are there so few views of this video? Stan explains how to split the water molecule in detail. there are a few more on google video,watch them and pay attention! ;D
http://www.youtube.com/watch?v=RRXlm5AO9mY&mode=related&search=
IronHead
Ok guys you are looking at 2 different system on my Youtube page SGiHunter.
The plasma heater for heat and the HHO system.
The HHO system is Hydrogen Oxygen production at 150F degrees 90VDC
It must stay at this temp or it will  steam very fast so it must be cooled with radiator. This is why I am running the bench system for a shot time . If I ran it longer you would see steam billow " A hell of a lot in a very short time" from the canister.
So what you are seeing is a dirty quick build bench top version of the system I run in my vehicle.That system design is on page 5 . I will soon be removing this system from my vehicle ,to remove and replace the Silver with Nitronic as the Silver is breaking down .
Do not use Tungsten in this system on the oxygen side, It will dissolve.
People are asking me how much gas is produced .I am no scientist I build what works for a given application. So this system on "page 5" produces enough for what I need it to do , get more bang for the buck on a big block 454ci engine.
BTW "Moab"great job you are on the top of my list of just do-ers . The "Just done it" list as it were.
You did it with out a zillion question about this that and the other scientific blah blah. Keep up the good builds
This is a very complicated system to run in a vehicle.
If you want something easy and that is proven ,buy a MagDrive
Just Build It
just do it!
IronHead
IronHead
Ok now,
The cold fusion plasma system.
One 1/8 tungsten welding rod (Green Tip)
One 100 micron 316L stainless steel Paint sprayer Graco filter mesh 1"Dia  x 4"long.Make sure the rod is right in the center of the screen tube.Make all connection solid and arc outside the water will go BOOM.
Now on the Tungsten you must cover with Teflon(Good for last hours) or coat in ceramic (Prefered last for months) all of the rod except for about 1/2" at the tip arc end.
120AC rectified  and non smoothed. You get about 118vdc 120hz.Start up is 30 amps  final at high temp is from 1.0 to 0.1amps
This is a good start.
Now you will not see a reaction in this till you hear it start to vibrate at about 130*F
At 150F to 160F you will get your arc .This can take from 10 min to 1 hour depending on your water. Adding abit of baking soda will help but will also raise start up amps.
baking soda also reduces Magnetite.
This type of system has run for months ( Rod adjustment weekly)before rebuild using a radiator to keep temps at bay.150F to 200F  do not let it go below 150 as it will become unstable.
If you can move this thread for me "hartiberlin" from page 5 on.
I will tell yaz about Feqs for both system not everything but enough for you to see and BANG--BOOM for yourselfs. Just don"t hurts yourselfs , I dont need that on my poor fragile mind
Just Build It
IronHead
otto
Hello all,
IronHead,
I was working a lot with this cold fusion system and as I can say its OK BUT there is a big problem: the tungsten welding rod is consumed!!! This means that the welding rod is thinner and thinner and in 1 hour work you can clearly see the rod is thinner.
Of course there MUST be baking soda in the water or and the vibrations are really loud and of course you can see it.
A warning: the water is boiling.
About the system on page 5. Maybe you could make a drawing with the dimensoins, if not asked too much??
Otto
IronHead
Quote from: otto on March 08, 2007, 01:39:03 AM
Hello all,
IronHead,
Otto
For the  CF Plasma Cell
Your arc was to hot . I will post pics of a rod that ran for 30 hours straight using the method im am using. Notice the reaction in my cell is not white hot.
Also this is a  circulatory heater and is not to be run constantly. I will explain this further,ether when the post is moved or when I start a new one .
IronHead
