Magdrive HHO Generators
Started by ZeR888, September 12, 2006, 05:42:34 PM
mikestocks2006
The 64 trillion dollar question still remains.
Can it produce more power per unit volume of H HO created, than the power  required to create the H HO unit volume?
A simple litmus test would be:
a. Hook up the Hydrogen generator gas out put to a e.g. portable electric generator ( like the small back up ones used for power outage at home 4 cycle piston gasoline powered)
b. Take the electric output from the electric generator and feed it to the Hydrogen generator.
c. If it produces enough H HO to run the piston engine and there is electric power left over then that's it!!!
In the car examples movies the piston engine drives the alternator that feed the car battery which feed the H HO generator who's gas output (H HO fuel) is plumbed into the engine gasoline/air intake.
Is there enough horsepower left (if any) to drive the car after the above loop's requirements are met?
If yes then that's it!!!
If not, an economic study needs to be performed for the usage of the system vs gasoline assuming there is an overall engine efficiency improvement. A customer will only be concerned about overall efficiency improvement without loss of normal power output.
Anyway it seems a lot of people are working in the right direction.
Thx for the links.
You can have a look at their homepage
where all videos are linked to.
http://www.fuelfromh2o.com/index.html
They claim, that they can run a motor just by their
HHO gas, but they say, the motor then rusts too fast,
so it better to mix it with normal gasoline fuel.
It seems they can really produce more gas than is
needed from the alternator as electrical input, so they
have enough power left to run the motor and drive with it
and the alternator keeps on running the electrolysis via the
car battery.
As hydroxy is really much more explosive than gasoline,
it seems to have more power during combustion than gasoline-air
mixes, so there is more power coming from the engine this way.
mikestocks2006
Quote from: hartiberlin on September 14, 2006, 04:18:42 PM
car battery.
If they can run the car without any gasoline and the battery is still fully charged at the end of the trip, then they have done it! True power from water only.
In regards to rusting effects or possible hydrogen embritlment, maybe use of different materials for the combustion chamber walls, head, and valves would help, or possibly another type of engine all together?
Unless I missed it on that link, their system is an add on to be used along with gasoline with good fuel cost saving according to their tests. Do they have a 100% water powered car demonstrating extended drive and under normal driving conditions?
Stefan, Thx for the link(s).
Yes, they have:
Watch this:
http://www.fuel-from-water.com/inside-super-gen-part2.html
Also they state it in their FAQ, that the biggest SuperGen
can run alone a car:
http://fuelfromh2o.com/cgi-bin/faqgen/faqgen.cgi
