Quanta Magnetics Experimental Kits
Started by Scorch, October 15, 2014, 02:06:58 PM
nelsonrochaa
Quote from: Pirate88179 on October 30, 2014, 09:57:04 PM
That looks cool and, it looks like you put a lot of work into it but, that 4 watt bulb that you light in the first video link can be driven by a single "dead" AA battery and one of my joule thief circuits.  It will light it for many, many hours.  That is with just about .8 volts compared to your 20 volts input from the solar cell.  I guess I am not seeing the utility of your circuit here.
It does look cool though and I appreciate your sharing it with us here.
Bill
Hi pirate88179,
The 4w bulb is not the point off the video is only a "add" in the circuit.  The main propose of the circuit is collect radiant energy and convert in large current.
I think there is a misunderstanding as to the circuit. I now what is a joule thief, I already made ​​dozens of prototypes "https://www.youtube.com/watch?
v=GmlpV1MWm40" but is not the point .
Can you make a joule thief and  able to connect the halogen bulb 12v 55w like in the video ?
That is the real propose of circuit ! Not light  in the ac output a lamp of 4w led :) The circuit have 2 output :
AC and DC . The DC output is high current .
the circuit  will collect radiant energy without use the main source to the output.
If you have some doubts see this video for you understand what i try to show and i have sure that you will understand .
https://www.youtube.com/watch?v=pf_qUlwSZl0
Is not a joule thief! Is a radiant amplifier.
MarkE
Quote from: nelsonrochaa on October 31, 2014, 06:58:50 AM
Hi pirate88179,
... snip ...
What evidence do you have that supports this claim?  Where is the radiant energy measured before and after the alleged amplification?
nelsonrochaa
Quote from: MarkE on October 31, 2014, 07:57:16 AM
ahhhhhhh ok you need the measures ...  i can provide a amp meter in the input but i don't have other to the output ,; the 55W 12v halogen car at full bright do the work to show the power collected ?  For the test you prefers a battery to the input of the circuit ? I can provide a video with this.
But think :
Why i firstly connected the halogen lamp into he solar panel ? For show that solar panel cant provide the wattage of the lamp the filament cant glow  (The solar at 100% conditions will generate 15W but not the case ) and i show in the circuit a output of higher power that can provide power enough to run the 55w 12v halogen bulb.
But if i use a 12v battery the result will be the the same .The power amp collected and storaged is more higher that main input.
I only need the main power to make the relay operate is the only real condition (car relay 12v) all the power collected is produced by BEMF like a joule thief. The difference between joule thief  is that if you use a transistor to the oscillation you cant combine the 2 positives charges because the transistor will burn and you don't be able to produce the effect. The contacts of the relay will act like a green spark " https://www.youtube.com/watch?v=DfxEAQNOjp0" produced bye the combined high current with the high voltage of BEMF.  Do you now anything about Edwin Gray and their technology? you can visit the Aaron Murakami channel and make some consult about this phenoms.https://www.youtube.com/watch?v=GX9XCK3RNuI&list=UU-41VqjATdRAlN7ztX8S30A
As you have the right to question my work, I also have the right to question whether you understood what was really going on this .
thanks
MarkE
Quote from: nelsonrochaa on October 31, 2014, 10:40:22 AM
But think :
thanks
If one wishes to claim that process X amplifies quantity Y, then one must show that quantity Y is greater at the output of process X than it is at the input of process X.  You claim amplification of radiant energy.  Therefore you must show the energy in and out of your process.  Amperes are a measure of current.  Amperes are not a measure of energy.
nelsonrochaa
Quote from: MarkE on October 31, 2014, 12:02:16 PM
Hi MarkE ,
I never say amperes are a measure of energy  ok i know the ohm law .
I make a new video with a a amp meter on the power source and with a 12v battery with the voltage monitored with a multimeter. is the best i can show now.
https://www.youtube.com/watch?v=YegRP2521jI
thanks for your opinion
